Those cool headlights?
Old Mar 19, 2003 | 11:56 AM
FerrMaro's Avatar
Cool Those cool headlights?
i know somebody has them but i forget who. they are that cool blue color. Thanx
Old Mar 19, 2003 | 05:52 PM
FerrMaro's Avatar
no one???
Old Mar 19, 2003 | 06:11 PM
stanghunter211's Avatar
I dunno if you are talking about these, but I got mine off ebay....
They are much brighter than stock and more white
http://images.cardomain.com/member_i...46_15_full.jpg
Old Mar 19, 2003 | 07:44 PM
jayman350's Avatar
did those come with a wiring harness for the new lights? I've seen a couple different auctions for those and I really want to do the conversion, i Just want to make sure i get the correct ones that will fit right in and actually work
Old Mar 19, 2003 | 09:50 PM
Irocvette355's Avatar
I would like to get those too...anybody know where, besides E-Bay?
Old Mar 19, 2003 | 10:33 PM
Ebay is the only place you can get these. I opted for these because they have lil 194 "running" lights in the bottom that you can rig up to say the ignition and off when the regular lights are on. Anyway, they did come with a wiring harness. Specific to high and low beams. I did run into a problem though. These H$ bulbs require alot more power than stock, and the higher voltage confuses the stock wiring harness and spikes the headlights. This causes them to start blinking violently after about 10 seconds of use. SO I was really pissed off to say the least and started picking around. What I found is that these new harnesses have a 3rd wire on each harness(one per light) which makes tries to duplicate the stock setup of all four lights on when the highs are activated. If you do not add new relays and wiring, there is no way that all 4 can be on without them all flickering, or one being brighter than the other. Long story short, I cut THAT one wire on all four harness and no more blinking. Only thing is they only work 2 and 2. Small price to pay I think for much improved visibility and an sweet look........ I say go for em. I got mine for 40 a pair buy it now. Came with bulbs, harnesses, and rubber plugs to keep water out. All and all I am very pleased........ Hope that helps guys
Will
Old Mar 19, 2003 | 10:40 PM
http://images.cardomain.com/member_i...46_41_full.jpg
Here is a pic at night. I will try and get one of the road at night so you can see the range. I must say when other cars around it is not even like your lights are on. WIth all these new HID cars around, they kind of drown mine out. But when its really dim on the highway, with not too many cars around, it is unbelieveable.
Anyways, these were the very best ones. I too waitied a while seeing all the different ones for sale and snapped these up a few months back when I saw em. I am gonna get another set as one has already cracked from a big ole rock that decided it didnt wanna stay on the road but in my light.....
WILL`
93 RedBird
Nov 15, 2015 08:24 AM
CARiD
Sep 30, 2015 05:44 AM
Greg88
Sep 20, 2015 07:14 PM
cmsmith
Sep 14, 2015 09:09 PM
jackpawt883
Sep 10, 2015 08:53 PM
