think i could get into the 13's??
Old Jan 14, 2003 | 02:51 PM
Black91Z28's Avatar
Mods are in sig along with the addition of a transgo shift kit (1-2 accumulator, boost valve, vette servo, etc.) Think 13's are possible in the 1/4 ?
Old Jan 14, 2003 | 05:31 PM
ThirdGenZ28 92's Avatar
At sea level in good air I think its possible depending on how well your car is running. Add drag radials and 1.8-low 1.9 60fts and it should be there consistantly...
Old Jan 14, 2003 | 07:07 PM
jd13's Avatar
Very possible. You're probably already pretty close.
Old Jan 14, 2003 | 09:27 PM
bigmike92z's Avatar
Yes. I plan on doing so this weekend with similiar mods.
Old Jan 14, 2003 | 09:39 PM
mjcent922's Avatar
ADD 2800 stall converter with bfgdrags and you will be there.
Old Jan 14, 2003 | 10:41 PM
Black91Z28's Avatar
where can i find a good stall at a good price? and how much would it cost to get one put in?
Old Jan 15, 2003 | 12:57 AM
aklim's Avatar
Try Jegs. LPE sells one that is about 500 rpm above stock stall.
Install is basically an R&R of the tranny. You have to unbolt it from the flexplate and take out the starter, then you have to remove the crossmember and the torque arm and there it is. The cooler lines are bendable so it should not be too difficult to remove them. Tranny out, take out the old TC and insert the new one and reassemble. Talk to a tranny shop
Old Jan 15, 2003 | 05:08 AM
I got mine from SLP, 800 over factory stall and Ive had it for atleast 15k miles and lots of trips to the track and no problems. Its my daily driver 50 mins each way to work and my 60fts went from 1.9x to high 1.7s on tire so yeah converter and drag radials will definitely help just make sure you add a cooler for the tranny while youre there.
Old Jan 15, 2003 | 09:45 AM
bigmike92z's Avatar
Robert, mrr23, introduced some of the locals to a vette converter made by dacco/detroit that stalls to about 2100. cost is 75 bucks and some members have had this converter on the car for almost a year of daily driving and abuse now. he also mentions he used it on his previous car and sprayed it into the 12s on that converter.
get a hold of him if you need info on picking one up.
Old Jan 15, 2003 | 11:14 AM
2IROC's Avatar
It would be hard to say. Do you have times before you did your mods?
I would say " no". Low 14s yes.
I think you would need a stall and some ETs to get you there.
Old Jan 15, 2003 | 11:58 AM
Chris Ja's Avatar
Eternal Member
I think you should use a higher stall converter. B&M makes a 2400 and I have one in my car. I would like to get a 3000 stall but money is tight. I got a N20 kit the other day. After I save a little money I will get the 3000 and sale the 2400. If you want to keep a eye on the board I will sale mine in a few months. I will be looking for 3 hundred for it plus shipping.
I also have a 3000 non lock up converter that is new but I would not use it on a street car.
I just called a guy about doing a lock up switch for the 3000 stall. If he can then I may sell it sooner.
Old Jan 15, 2003 | 12:44 PM
Black91Z28's Avatar
in the future (within 2 years) im doing a cam, heads, and intake swap so i'll want a higher stall on this car, think i should just wait until then?
Old Jan 15, 2003 | 08:20 PM
kandied91z's Avatar
yep....even with what i'm doing i'm staying with the same size as when i had stock power...
my L98 hit mid to high 13's with just CAI and a nice exhaust.
the 350's need to breath. keep an eye out for a good intake that's cheap and you'll get there easily.
seriously though it would help to know what your running as you are now to tell.
Old Jan 15, 2003 | 09:13 PM
Black91Z28's Avatar
im doin the LT1 intake i believe
Old Jan 15, 2003 | 09:51 PM
IROC5.7TPI's Avatar
I had a 2500 Dacco in my TPI Vette and sprayed 150HP and it lasted a good 3 years and it had no problems when I sold the car.
I have another Dacco 2500 from my IROC sitting on the shelf that I just took out...
BTT- The car in question should pull 13's as is. If not a converter and tires will make sure it does....
