TH 350 tranny????
Old Aug 17, 2003 | 02:15 PM
amc91z's Avatar
TH 350 tranny????
I'm wanting to get a TH 350 for my 91 Z but dont know if I need the long or short tail shaft...anyone know??? What else do I need to get to get it all to work? I know I need the torque arm mount, but what else?
Thanks,
Adam
Old Aug 17, 2003 | 09:50 PM
Geezer powered's Avatar
long tail shaft I believe.
Old Aug 17, 2003 | 10:12 PM
amc91z's Avatar
anyone know for sure? I can get a short tail shaft tranny from my uncle for free. could I just get a longer drive shaft or would it be better to find a long tail shaft tranny?
Thanks,
Adam
Old Aug 18, 2003 | 05:12 AM
Cam28_boy's Avatar
I have a 1991 with a short tall shaft th350...I ended up buying a new tailshaft that was longer. I was told after I already had my trans built that if I would have used a long tail shaft th350 I could have retained my stock driveshaft.
Old Aug 18, 2003 | 09:08 AM
12Second3rdgen's Avatar
Short tail shaft transmissions are cheaper and easier to come by. I would get a short tail shaft transmission and then get a driveshaft out of an 82-83 f-body with a 200c 3 speed automatic transmission.
Old Jan 24, 2004 | 10:51 AM
amc91z's Avatar
what crossmember do I use with a short tail TH350?
Thanks,
Adam
Old Jan 24, 2004 | 11:31 AM
Stephen 87 IROC's Avatar
The rear mount is in the same position on both long and short tailshaft TH350's. The swap kit available supplies an adaptor bracket to convert from the 700R4 to TH350. It also provides a way to mount the torque arm onto the tranny however I'd suggest getting an aftermarket torque arm such as the one from www.spohn.net
The 9" long tailshaft TH350 uses the same driveshaft as the 700R4. The 6" short tailshaft can use the driveshaft from an 82-83 F-body that came with the metric 200 3 speed.
Old Jan 24, 2004 | 04:23 PM
95NateZ28's Avatar
Or you can use either and just get a custom made driveshaft.
And I definately recommend the Spohn Torque Arm/Crossmember assembly. Awesome piece!
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
HAWG
Sep 25, 2015 11:41 AM
