test pipe??
Old May 1, 2006 | 12:30 PM
House's Avatar
test pipe??
where can i find a test pipe for a 3rd gen??? aka cat delete pipe
Old May 1, 2006 | 08:51 PM
LesPaulGoth's Avatar
Re: test pipe??
Go to autozone, get 12+" straight pipe at the diameter you need, proceed to cut down to proper size with saw zaw, weld into place.
Old May 6, 2006 | 09:35 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Re: test pipe??
Removing your emissions equipment on a street vehicle is a FEDERAL offense, regardless of your state's emissions requirements. If you're caught, you can be punished with a fine, jailtime, or both. Putting in a "test-pipe" is illegal, therefore you cant buy one pre-made.
Old May 8, 2006 | 12:07 PM
irocalot's Avatar
Re: test pipe??
"Removing your emissions equipment on a street vehicle is a FEDERAL offense, regardless of your state's emissions requirements. If you're caught, you can be punished with a fine, jailtime, or both. Putting in a "test-pipe" is illegal, therefore you cant buy one pre-made."
talk to your auto parts store - generic replacement cats are usually a set length (about 18") with no bends, and slip-fittings on both ends. Most aftermarket cats require an adaptor kit to fit your vehicle, with the proper fittings to fit onto your car. buy the kit, and a piece of straight pipe, and you too, can be an "outlaw"...
evidently you'll want to stay out of california, texas, and other "law and order" states...
naaz90
Jul 27, 2002 08:22 AM
TrouserSnake
Jul 22, 2002 06:53 PM
