tbi to a carb help please!!!
Old Feb 15, 2005 | 06:50 PM
streetheatz28's Avatar
Exclamation tbi to a carb help please!!!
I am putting a holley 600 cfm carb with a weiland x-celerater intake inplace of my stock tbi system how do i hook up the wires to tell the fuel pump how much to flow??? do i need a diffrent fuel pump? thanks..
Old Feb 15, 2005 | 07:12 PM
NOMAD's Avatar
Re: tbi to a carb help please!!!
You will probably need a Mallory 3 port regulator if your using the electric pump. Retails for around $80 through Jegs.
-Shannon
Old Feb 15, 2005 | 09:33 PM
RED396's Avatar
What is the part number for the regulator? I am in the process of converting my 396 to carb.
Old Feb 16, 2005 | 02:28 PM
Rice Killer87's Avatar
http://store.summitracing.com/defaul...=egnsearch.asp
thats exactly what you need,im running it on my car and have been for a while when i switched from TPI to carb.
Old Feb 16, 2005 | 09:17 PM
Solidous_Snake's Avatar
Why would someone turn a TPI to carb? Does it run faster?
Old Feb 17, 2005 | 11:54 AM
icemanrs305's Avatar
im almost done my tbi to carb swap (LO3 - 355 carbed), i didnt have the cash for the mallory , so i just picked up a $25 holley mechanical reg, and i had a auto meter fuel pressure gage already , so im going to use that. might not be the best way, but ive heard from 2 different people that it works fine. and they are running 12's and 13's with this fuel set up on a stock pump. but i have a question about the fuel pump. will it still turn on with the car after the computer delete? or will i have to hook it up so it has a manual on/off switch in the car that ill have to turn on each time i wanna start up the motor?
Old Feb 17, 2005 | 12:00 PM
RED396's Avatar
The reason why my motor is being converted is because right now I don't have the money for the FAST system to tune it. I'm going with the victor jr efi intake and a demon 850 carb. So when I get the funds, converting back over will be easy.
Old Feb 17, 2005 | 12:18 PM
TPI get better gas, but Carborated are generally faster, right?
Old Feb 17, 2005 | 04:34 PM
Originally Posted by robvas
Why not just get a tank from a carb'd 3rd gen?
the tank isnt different,the only difference in the fuel level sending unit (b/c i think carb'd third gens had a mechanical pump) and that alone is like 300 and some odd dollars...just for a sending unit! thats why i didnt switch to that.
plus an electric fuel pump doesnt put any drag on the motor like a mechanical one does.
Solidous_Snake-
i changed my car to carb b/c i wanted to go fast w/ spending an azzload of extra money... cheap horsepower is pretty much what i was after. in order for me to run my Vortec heads w/ that TPI,i would have to buy a special intake base for $300-$350 JUST to run the heads. then i would have to get it tuned for the cam im running...another $300-$400. so instead of pissing away almost a grand to run the setup i wanted,i switched it to carb and the only thing i lost was gas mileage...which i didnt care about b/c the car doesnt get driven alot anyway. my cars an 87 and only has 121k on it.
i sold my TPI and wireing harness on ebay and got enough money to buy my intake and carb off ebay,with money left over to the little things like fuel lines and fittings.
i went from a torquey L98,to a 400HP carb'd 350 .040 (357) that should run low 13's high 12's with traction and a 650 carb.
im basing those time off of a 94 GT stang i ran a few weeks ago w/ 3.73's,shorty headers,CAI,off road H-pipe,1 chamber flowmasters,short throw shifter and prob. some small things i forgot,but i beat him by 3.5 to 4 cars from a slow roll and we didnt race a full 1/4 mile.
hope that clears some things up
Old Feb 17, 2005 | 06:20 PM
Thanks for replying and it does make more sence now.
Kawi
Sep 28, 2015 09:01 AM
92_RS_305
Sep 8, 2015 07:47 PM
kylekratzenberg
Classic Engine Tech
Aug 25, 2015 10:28 PM
Jmlcolorado
Jul 4, 2015 08:31 AM
