taking off front bumper
Old Jul 5, 2003 | 01:34 PM
kevin 2.8's Avatar
im trying to replace my headlight bar, i want to take my front bumper off without ripping it apart
im having problems with the six or eight bolts that are hidden by the side fenders, the driver side has the horn sort of in the way...
am i supposed to take off the fenders first?
Old Jul 6, 2003 | 01:25 AM
kevin 2.8's Avatar
aw comeon my car has a lazy eye
someone must have taken apart their front end
ttt
Old Jul 6, 2003 | 09:18 AM
AutoRoc's Avatar
estghd
While taking my buddies RS apart last year I know we decided to NOT remove the headlight bar because it was a serious hassle once we seen how it was fastened! Goodluck, wish I could help.
Old Jul 6, 2003 | 01:56 PM
Damon's Avatar
Leave the fenders in place- they align with the front nose cone and you want to have to adjust as few things back into spec later on as possible (ESPECIALLY if you are reusing the original outter nose cone- these pieces "mate" to eachother over time and don't take kindly to readjustment after being together for several decades).
I got the 4-6 bolts holding the nose cone to the front lip of the fender off by removing the horn and anything that was in the way of me putting a wrench or socket on it. I recall using a variety of whenches, sockets and extensions to get at them, from both above and below the car.
Remember that the lower "chin spoiler" also bolts to both the nose cone (a bezillion bolts along it's length) and several bolts along the bottom/front edge of the fender. I recommend unbolting the chin spoiler from the bottom of the fender but leaving it attached to the main nose-cone as an assembly, again, so there's less to re-align later.
Use a LOT of penetrating oil on the bolts and let it work for several days if possible. 90% of these bolts are stud-and-nut type fasteners and can't be easily replaced if you snap them off.
Old Jul 6, 2003 | 02:49 PM
kevin 2.8's Avatar
ok i too k the chin spoiler off, and i got all but 1 bolt on each side off... second from the top passenger side is stripped, im taking the carbide dremel to it soon
and the top one driver side is still on, its a bugger.
ill try again later
after i get all those out and the push plugs i assume the plastic facia will slip right out
then its to tying the metal bumper to a tree and straightening it out
Old Jul 6, 2003 | 06:52 PM
kevin 2.8's Avatar
yep.
tied it to the tree and stomped it a bit, its all straight, put the headlight bar in and the bumper on.
took me almost all day but i got it.
too many bolts i have a handful left over.
must be spares
thanks for the help. beer is in the fridge
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Jun 6, 2015 08:27 AM
CARiD
Feb 9, 2015 09:35 AM
heavenly_six
Dec 10, 2014 12:23 AM
