T5 to T56 swap in an 87 IROC
Got $1350 in mine. Check the sig for a complete write-up. The swap is really a piece of cake. For an '87, instead of a dakota digital SGI-5, you'll need a cable-x box (pretty pricey though). Later man, btw the swap is TOTALLY worth it!!
-Rippin
-Rippin
Find a LT1 donor car and get everything from it that you can. Pedals (not necessary if you have a stick already), cables, lines, driveshaft, EVERYTHING!! That will make the swap much easier. The most expensive thing will be a conversion box to convert the electrical signal to a mechanical signal for your speedo. Total, you're looking at anywhere from $1000 to $2000 to do the swap depending on what you can find used and what you have to buy new. You will also have to modify your cross member and the hole in the tranny tunnel for the shifter to fit through as the T56 shifter sits farther back than the T5. You will also have to have your drive shaft shortened unless you get the one from the donor car, it should fit ok.
Good luck.
Good luck.
Good luck.
Good luck.
-Rippin
Good luck.
Good luck.
all the f-body driveshafts 82-02, were the same length, except the 82/83 with the 3-speed auto or the 4-speed manual transmissions
I was gonna say something about the driveshaft but I see it's already been covered....
I spent right at $2000 swapping my 6-speed in, but that's with a stage 3 clutch and a brand new Ripper shifter and a Centerforce flywheel and new hydraulics and synthetic fluid and all that. I could have done it for around 1200 if I hadn't gone all-out.
And that's converting from auto so you could even do it cheaper.....
Stealth: I posted a WTB ad in the Parts Wanted Section. A guy emailed me and I bought it. Simple as that
On ebay they always go really high and yards rarely have them. Keep an eye out for cars being parted out. I've seen a lot of T56's go for cheap with a bad synchro or something. If you know the insides of a manual tranny, you can pick one of them up and rebuild it for pretty cheap.
J: Your flywheel was the conversion one too so it cost like $300 didn't it? Man the 6-speed is so sweet, I turn 1600 RPM at 85mph
It's great!
udmwye96z: If you want to get technical, once I sell my T5, I'll really only have $1000 in the swap.
-Rippin
On ebay they always go really high and yards rarely have them. Keep an eye out for cars being parted out. I've seen a lot of T56's go for cheap with a bad synchro or something. If you know the insides of a manual tranny, you can pick one of them up and rebuild it for pretty cheap. J: Your flywheel was the conversion one too so it cost like $300 didn't it? Man the 6-speed is so sweet, I turn 1600 RPM at 85mph
It's great!udmwye96z: If you want to get technical, once I sell my T5, I'll really only have $1000 in the swap.
-Rippin
Rippin: How much do you asking for your 5 spd? And how much would it cost to convert from my auto.?
Stealth: What kind of cam did you put in your 305 TPI? How much was it?
93 or 94 LT1 cam, got it for free with like 34k on it, measured .456 intake lift i believe. One big PITA to do the swap, I only did it to get my hands dirty and work on my car, not worth it since I pulled the 305 months later.
-Hydros
-T/O Bearing ($10)
-Pedal Assembly
-5 Spd Console
That's all I can think of. PM me if interested.
-Rippin
Corey: Yes, the flywheel I used was the Centerforce "T-56 on a 2-piece RMS" flywheel. Part #700107 and it ran right at $300. Also, 85mph=2000rpm in 6th with the 3.70's.
Stealth: I got my T-56 from a guy that knows a guy that hangs out with a friend of mine. I just put the word out with all my "hotrodding" friends that I was looking for one cheap and it eventualy came up. The guy sold it to me for $500 because it wouldn't stay in 4th and it wanted to grind going into 3rd....replaced the 3-4 shift fork for about $50 (including fluid and such) and it works like a charm. Just watch out for trannies with bad synchros. Synchro kits for the T-56 are pretty pricey.
Here's an nother option, if you want new.
http://www.sallee-chevrolet.com/BorgWarner/bwt56.html
Can be purchase from any Chevrolet Dealer.
Isn't MacLeod making an adaptor to mate any T56 to just about any domestic V8? You specify what the transmission came from and what it's going to be mated to and they send you a bellhousing or an adaptor or something. I believe Hot Rod did a story on it a month or three ago.
