Synthetic Oil
Old Sep 24, 2003 | 09:04 PM
shwine617's Avatar
Synthetic Oil
I want to start to run my car with synthetic oil, I am going to use a blend once before i switch over. But I am not sure which brand to use. I want to use one that is around $5 a quart. I think Mobil1 and Castrol Syntech are good. Any suggestions?
thanks!!!
Old Sep 24, 2003 | 09:26 PM
IROC350's Avatar
i'm not big on the synthetic stuff so i'm not sure what to tell ya man.
Old Sep 25, 2003 | 12:29 AM
aklim's Avatar
I have used Mobil 1. LPE and Callaway recommend it
Old Sep 25, 2003 | 01:18 AM
dj haf's Avatar
mobile 1 for me
Old Sep 26, 2003 | 03:22 PM
Ace_437's Avatar
So why the hell did you even post? Looking to up your count? I've been running Mobil One in my Z for the last year or so. I've read it's pretty good, but to me oil is oil.
Old Sep 26, 2003 | 05:17 PM
bmillington's Avatar
another vote for Mobil 1
Old Sep 26, 2003 | 06:28 PM
92BLKL98's Avatar
Amsoil bumper to bumper
Old Sep 26, 2003 | 07:36 PM
aklim's Avatar
I would drain out the motor by letting it sit overnight with the screw out and changing the filter and replacing the screw before I put in the new stuff. Wouldn't bother with a blend. Just go straight. LPE had me run 30W oil to break it in and this was in the middle of winter. Had to keep it heated in a garage when I got home, drove the hell out of it for 500 miles, changed oil, 500 miles, changed to Mobil 1 but 1000 miles later, I changed again and at 3000 once more just because I am paranoid.
Old Sep 26, 2003 | 09:29 PM
jasons93z's Avatar
I was thinking the same thing . I use mobil 1 myself. Synthetic is the way to go
Old Sep 26, 2003 | 09:43 PM
lordmetalz28's Avatar
dont leve your drain pan open overnight you might get a hatian or mexican stuck in there overnight yeah seriously dude why did you post. just drain it good for like 2 hrs then bam your all set oil is oil personally i recommend valvoline max life and lucas additive does wonders on pressure
Old Sep 26, 2003 | 09:59 PM
cd520's Avatar
Old Sep 27, 2003 | 07:34 PM
RadarRunner's Avatar
I don't think you will go wrong with either Mobil 1 or Castrol.
I use the Castrol synthetic in my wifes' 2002 T/A, but use regular Castrol in my 87 Z28, 87 Honda M/C, & 88 Bronco.
I've heard of Amsoil & Redline, but the two names you mentioned up top are readily available.
On your 355 TPI, did you rebuild it yourself or have a mechanic do it?
Old Sep 28, 2003 | 07:56 AM
Geezer powered's Avatar
Mobil 0w 40w best off both worlds.
Old Sep 28, 2003 | 10:13 AM
mechanicZ's Avatar
ya 0-40 or 0-30 is good, if ur engine doesnt burn it like crazy
Old Sep 28, 2003 | 08:02 PM
shwine617's Avatar
I bought the car with the motor already in it, i talked to the kid i bought it from and he gave me the mechanics name who did the work. I am going over the whole motor to make sure everything is good. I really want to but a holley stealth ram, 58mm TB, 200cc/65cc heads, and 26-30 lbs injectors.
anyway, I think the votes go to Mobil one for me. I also heard amsoil is really good and tha "all the guys at the track use it" but i never see it anywhere and its probably expensive. Mobil one is in the Shoprite by my house.
thanks guys!
