Suggestions for a new timing chain
Old Sep 21, 2003 | 02:23 PM
Night Rida''s Avatar
Hey Gang,
Im about to do some preventive maintance on my 91 camaro with a 305 tbi.It has a 120K and i want to change the timing chaing before I damage anything else if the chain decides to go.Are there any reconmendations on which one to buy?A timing set from autozone or napa or kragen cost 40-50 bux.Should i just opt for the edelbrock timing set or should i get a gear whine one from pete jackson or somewhere else.All and any info will be greatly appreciated
Old Sep 21, 2003 | 10:53 PM
90rocz's Avatar
Well, the '91 has a roller cam, this means early model sets or gears won't work. I'm not aware of a "noisy" set that will fit but, Edlerbrock sells a gear-to-gear set for about $160, but Dynagear sells a Double Roller set for about $50. Not much of an advantage below 7000rpm, so I'd go "Double Roller"...
Old Sep 22, 2003 | 12:01 AM
Thanks for the info...So what kinda timing set should I be looking for?
Old Sep 22, 2003 | 12:27 AM
Zepher's Avatar
I went with a Cloyes Double Roller.
$90 from Jegs.com
Old Sep 22, 2003 | 12:30 AM
That looks saweet.How hard was it to install also is there any hp/torque gains from putting in an aftermarket chain compared to a over the counter napa/autozone brand?
Old Sep 22, 2003 | 12:51 AM
Zepher's Avatar
thanks.
My friends have this chain and they say that they have much better throttle response.
Install is just like a normal timing set.
Old Sep 22, 2003 | 12:53 AM
do you have the part # or is it different for my year
Old Sep 22, 2003 | 12:56 AM
Zepher's Avatar
You and I use the same chain.
This is the one,
220-9-3145
SB-Chevy, 4.3L V6, 1985-up with Factory Roller Cam $79.99
Old Sep 22, 2003 | 12:57 AM
is that for jegs or summit?Is it possible to ge the summit part # or would it be the same.Thank you for all the help.
Old Sep 22, 2003 | 01:12 AM
Zepher's Avatar
That is the Jegs part number and price.
Here is the Summit part #
CLO-9-3145
$79.95
Vendor: Cloyes Gear & Products Inc.
Product Line: Cloyes True Roller Timing Sets
Material: Steel
True rollerized timing from Cloyes
Chevrolet: 1985-95 305/350, 262/4.3L V6, true-roller timing set
This Cloyes True Roller timing set features a full, roller-action Renold, double roller, chain made from high strength steel for superior durability. The cam sprocket is made from heat-treated cast iron, while the crank sprocket is machined from high carbon heat-treated steel for strength. With three key ways for adjustability, 4 degrees advance, 4 degrees retard, and normal, this set is hand matched to ensure precise chain tension.
Old Sep 22, 2003 | 01:21 AM
your the man =)!!!!!!!Do you know if the edelbrock timing chains are as good?
Old Sep 22, 2003 | 01:31 AM
Zepher's Avatar
They should be good. I just don't know anyone running one.
Old Sep 22, 2003 | 01:38 AM
cloyes it is.....Is there any other small stuff i should buy while im at it?I already changed the water pump....
Old Sep 22, 2003 | 01:44 AM
Zepher's Avatar
Do you have the means to remove the engine?
Can you have the car down for a few days?
Do you have a little more money available?
If so, I'd pull the motor and freshen it up with new bearings piston rings, change all the seals and gaskets, possibly the oil pump. Should get you another 120K+ miles out of the motor.
Old Sep 22, 2003 | 01:48 AM
hmmmm that should set me back another 3-400 bux and down 3-4 days.Ill take that into consideration.Thanks once again
