Subs
Old Feb 24, 2004 | 04:11 PM
jchevy91's Avatar
Subs
Has anyone ever heard of any stories where their subs cracked their back window? I'm afraid to turn min all the way up. Any info?
Old Feb 24, 2004 | 04:35 PM
transxtreme's Avatar
Ha, yes it can be done ive SEEN it happen before, post details of your system, ie: wattage, type of subs, amp.
Old Feb 24, 2004 | 05:07 PM
jchevy91's Avatar
Alpine CDA-7873 Headunit
2 12" 1200 peak 350 watt rms Sony Xplods
700 watt Kicker amp
Old Feb 24, 2004 | 06:01 PM
Ville H. Valo's Avatar
My freinds Licence plate shook off from the subs.
-Ville
Old Feb 24, 2004 | 06:15 PM
Pro
Guest
Posts: n/a
If youre not a bass freak (that likes to show off to people you dont even know as you drive by them) then you shouldnt have a problem.
Old Feb 24, 2004 | 06:16 PM
jchevy91's Avatar
well if i have them all the way up....will it break is the question...anyone have any ideas?
Old Feb 24, 2004 | 06:30 PM
Open the hatch when you do it, dont drive with it that high.
Old Feb 24, 2004 | 06:40 PM
jchevy91's Avatar
anyone else with the same sort of wattage in their subs have any problems or?
Old Feb 24, 2004 | 07:06 PM
TheGreatJ's Avatar
1800w through 2 12" Audiobahn's in the back of my fiance's '00 Z and the hatch glass is still intact.
700w isn't enough power to break glass unless you catch some kind of perfect harmonic frequency. And Sony subs aren't clean enough to put out that kind of harmonic anyway.
Old Feb 24, 2004 | 10:33 PM
No, you will be fine. Even at peak RMS your subs will not be able to shatter that glass. I have a 2400 wat amp pushing 2 2400 wat subs which booms really loud. Im looking into getting a bullet proof lexan window cuz it makes me a little nervous.
Old Feb 24, 2004 | 11:34 PM
aklim's Avatar
It is not the power of the sub but whether the sound produced hits the right resonant frequency. If it does, it will shatter the glass.
Old Feb 25, 2004 | 10:02 AM
jchevy91's Avatar
so aklim will that blow my window? with the subs taht i have?
Old Feb 25, 2004 | 12:27 PM
aklim's Avatar
Well, we did this in science class where you have a sound, not that loud but it can be varied in frequency and when it was at the wrong frequency, the glass did not break. Note, the volume was not all that loud and only the frequency was varied. Once the right frequency was reached, the glass broke.
I believe that is why they don't have soldiers march over a bridge. If they march at just the right timing.......
Your subs will be fine until you hit the right note then it depends if it has the power to break the glass. Power alone will not really break the glass. When the pitch (frequency) of the voice matches the natural frequency of the glass, such large amplitude waves build up in the glass that it shatters. This phenomenon is called resonance. It is what made the original Tacoma Narrows Bridge collapse.
Old Feb 25, 2004 | 01:32 PM
Pro
Guest
Posts: n/a
Maybe if the hatch area was a completely sealed compartment it would matter? But since it shares air space with up front, it shouldnt...?
Old Feb 28, 2004 | 12:34 PM
highboost's Avatar
no it wont break ,you wont have enough air pressure with that combination . it took me 4 orion xtreme3 12 dvc's and a orion hcca 250r to break 86 t/a back glass.
