STUPID AUTO ZONE KID!!! needa belt size
Old Sep 12, 2005 | 01:01 AM
Runin2Nite's Avatar
So i finally got ridd of my air smog pump and a bunch of other useless crap (hoses and stuff). Any way I go into autozone and tell the kid i need a new belt and say clearly 3x THIS IS NOT THE STOCK BELT. I need a belt that has 6 ribs and is 96.8 inch long. dayco part # 968k6 he tells me he can't find it. i guess they dont got dayco and the boxs dont have sizes marked. Any way this kids comes back tells me he measured this one and says its 96 inchs long. I ask him clearly... THIS ISN'T the stock belt size on your computer correct, he says no its a diffrent one. get the bitch home and go figure its the same ficken size as my old 1. does any1 know what the gatorback belt size is that i would need???
Old Sep 12, 2005 | 12:35 PM
onefastgta's Avatar
Re: STUPID AUTO ZONE KID!!! needa belt size
Ask them for the belt catalog and look it up for yourself, or go to napa and do the same. If they let you pick your own, you can go in the back and get it yourself. Just ask them if you can pick your own from the back.
Old Sep 12, 2005 | 01:43 PM
350TPI's Avatar
Take your car and tools needed to remove the belt to autozone.Take the belt they give you outside and put it on.If its too small or big just take it back inside and get another until you get it right.Thats what i did and they dont mind taking the belts back.Good luck.
Old Sep 12, 2005 | 03:38 PM
respectirocz's Avatar
most size increments are in half inches
i doubt anyone would find a 968k6 unless its dayco but your belt tensioner should be able to compensate for more than a half inch maybe a 965k6 or a 960k6
by the way where did u get the information that u need a 96.8 inch belt?
Old Sep 12, 2005 | 04:00 PM
Ben91RS's Avatar
Just go to a different parts store. FWIW, I know for a fact that Advance Auto sells 968K6 belts, that's where I got mine from. I couldn't find any serpentine belt part number cross references online, but there's probably one out there somewhere.
Old Sep 12, 2005 | 04:54 PM
Dave89IROC's Avatar
http://www.daycoproducts.com
click "application guide" in the bar under the logo
Old Sep 12, 2005 | 04:56 PM
Dave89IROC's Avatar
btw, the dayco number is 5060968, not 968k6
Old Sep 12, 2005 | 07:15 PM
same difference
the 50 is unique to the manf
the 6 is an indication of the number of ribs and
0968 is the length
a goodyear gatorback belt uses similar
4060968
i dont need to explain that one do i?
belt sizes are easy to understand and i personally feel its easier to describe with 968k6
Old Sep 12, 2005 | 07:46 PM
Dave89IROC's Avatar
Originally Posted by respectirocz
same difference
0968 is the length
4060968
yeah, but if the kid at AZ doesnt know anything but the actual PN..........................
Old Sep 12, 2005 | 11:18 PM
Runin2Nite's Avatar
i got the part number from 3rdgen.org i found the rite belt i took it off my buddys iroc that had the same setup. i have the belt size for a gator back belt if any one needs it... i'll post it up 2moro
Old Sep 13, 2005 | 12:35 AM
iansane's Avatar
Unless the parts store nerd has only been working there a few days they should understand the PNs of each belt manuf. Just tell them you need a 6 rib 96.8" belt.
I think we have at least 4 in stock at my store all the time. Pretty common.
Dayco is a better belt but the same thing in a Drive-rite is a 5060968DR
HectorM52
Jul 30, 2017 11:46 AM
ChrisFrez
Feb 15, 2015 08:12 AM
ChrisFrez
Jan 11, 2015 03:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
