stock times for 305's and tpi 350's
Old Mar 2, 2004 | 08:43 PM
00blkw68fb's Avatar
whats up fellas just wanderin if my v6 2000 firebird with a lsd and 3.42's wit a flowmaster catback can keep up wit or possibly beat a third generation f-body i should be somewhere in the low-mid 15's im guessin so if u guys can give me some 1/4 times your camaro's and firebirds run stock, id appreciate it. thanx
Old Mar 2, 2004 | 08:47 PM
Black6SpdTA's Avatar
You sure can hang with/beat some of us! Here are some *general* times:
305 TBI - High 15's to low 16's
305 TPI - Low to mid 15's
350 TPI - High 14's to mid 15's
Old Mar 2, 2004 | 08:48 PM
angel71rs's Avatar
89 Formula 350 twin cat, A4, 3.27's. Chip, K&N filter, Flowmaster. 15 flat at local 4,100 ft altitude track. About 14.3 corrected.
Old Mar 2, 2004 | 08:52 PM
00blkw68fb's Avatar
thanx fellas! i was wandering, do u think my 18' rims slow my car down at all since its a v6? i didnt really feel any difference after putting them on
Old Mar 2, 2004 | 09:46 PM
krazzycowgirl's Avatar
14.79 @ 1/4mile total stock 87 Irocz 350 TPI at sea level.
14.66 @ 1/4mile 99% stock 87 Irocz 350 TPI at Sea level
Old Mar 2, 2004 | 10:00 PM
StealthElephant's Avatar
15.5 @ 89MPH 305 TPI 75k bone stock
Old Mar 3, 2004 | 01:59 PM
Zepher's Avatar
88 Formula 305 TPI Auto 3.23 , 15.7 @ 87mph. 112K miles on it slipping tranny. Car was bone bone stock.
86 Trans Am 305 LG4 5 Speed 3.27, 14.943 @ 91.67mph. Car had an edlebrock carb and intake, everything else was stock.
Old Mar 3, 2004 | 03:05 PM
IROCThe5.7L's Avatar
For the 350's your looking at mid 14's stock if it has the performance gears (G92), and high 14's if it dosent.
Mine has the 2.77's and ran a 14.82 with a kinda crappy 60ft. Should have been a 14.7x though.
Old Mar 3, 2004 | 07:39 PM
transxtreme's Avatar
BTW, a stock RS was rated at 16.8 @ like 80 something stock. Believe me its true, considering they only have 170 hp.
Old Mar 3, 2004 | 08:25 PM
Irocz85's Avatar
85 IrocZ with the 305 TPI ran a 15.2@91MPH
92 Z28 L98 ran a 14.4@95MPH.
89+305 TPI cars ran a 14.6 w/T-5 tranny.
3800 Camaro and Firebirds run a 15.8 stock.
All Motor Trend and Car and Driver times
Old Mar 3, 2004 | 10:36 PM
91chevyz28's Avatar
1991 z28 305 tpi 5 speed ran 14.6@97mph englishtown nj
Old Mar 3, 2004 | 11:04 PM
00blkw68fb's Avatar
if stock 305 tpi's are 170 hp , how are they pullin mid-high 14 sec et'swit nothing done? is it torque or gearing?
Old Mar 3, 2004 | 11:09 PM
91chevyz28's Avatar
i have read that a stock 305 in '90 and '91 w/5 speed HO had 230 hp and 300 torque
Old Mar 3, 2004 | 11:11 PM
00blkw68fb's Avatar
that should do it then lol
Old Mar 4, 2004 | 12:00 PM
MY91Y84's Avatar
there quite a bit of not totally correct info here....
the LG4..5 speed or not would be lucky to run a low 16...the L69 would be mid 15 and LO3 wouldnt get a 15 if it was pushed down the track
for the TPI cars alot had to do with it...
the AUTO LB9's were anywere from mid 15's to hi 14's...they were 205hp and 285 torque in there hottest form
5 speed LB9's With the 3.08's ran with the auto LB9 cars...probly a hi 14 if drivein well....
5 speed LB9's with the 3.42's (G92) were mid 14's off the assembly line...now if you cant drive it wont be that fast...
L98 cars with the 2.77's will be BEATEN by a good driver in a G92 LB9
L98 cars with 3.23's (G92) will run 14.1-2's off teh assembly line
my 91 G92 LB9 ran a 14.8@93 with a burnt clutch, hammerd throwout bearing, massive leak in the FACTORY exhaust and the original 10 YEAR OLD dry rotted tires
I put in a stock replacement clutch, and a exhaust shop press bent exhasut with flowmaster muffler, a K&N and ground down EGR walls and a set of tires...
took it back and drove the snot out of it to a 14.1@almost 97
i will walk LT1 cars to about 75-80
i will beat ANY non G92 L98
the G92 L98's give me a lot of trouble...i really have to drive it to hang with them, but i have beat a few of them
LS1's will be walked to about 40-45
