Stock hp for 87 Trans Am?
Old Jun 30, 2003 | 11:29 PM
Brodie's Avatar
What's the stock hp for an 1987 Trans am 350 engine. I can't find it anywhere!
Old Jun 30, 2003 | 11:32 PM
doug791's Avatar
you didnt look very hard http://www.thirdgen.org/newdesign/tech/techdb.shtml
Old Jul 1, 2003 | 07:29 AM
87DJP2001's Avatar
The 5.7 TPI was rated at 220 HP in the Camaro and about 10 HP LESS in the Firebird TA due the retriction of the air intake with the low hood. The Firebirds always had this problem because of the air intake, so some of the listed numbers will be incorrect.
Old Jul 1, 2003 | 10:23 AM
JohanZzZon's Avatar
wath about 89 trans am gta l98 then??
wath about my 89 trans am gta l98 then??
it got the dual cats
is the stock rating 225hp correct???
Old Jul 1, 2003 | 10:37 AM
87DJP2001's Avatar
Not with the retrictive air intake system. Unless Ponitac just forgot about it and said everything is equal between both versions now. Just compare the two, Carmaro/Firebird TPI intakes and you judge which one you want???
Old Jul 1, 2003 | 12:19 PM
angel71rs's Avatar
Stock rating for an 89 L98 twin cat is 240. And it is capable of making at least that much. My daily driver 89 Formula 350 twin cat ran a best 15 flat at our local 4,100 ft altitude track. Corrects to about a 14.3 at sea level. Modifications: Hypertech chip, K&N, Flowmaster. A loaded GTA would weigh more, so mid/high 14's would be expected.
Stock specs:
http://pontiac.sk/engines.php?&lang=eng
Old Jul 1, 2003 | 12:46 PM
87DJP2001's Avatar
If GM (quoted HP for the Firebird) is correct. Then the Air Intake systems between the Camaro/Firebird TPI did not make a difference as reported in earlier model years.
canbaufo
May 25, 2015 12:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
jb4xx
Feb 2, 2015 10:00 PM
Jan 5, 2015 07:14 PM
siguy
Nov 27, 2014 10:07 AM
