Still having an alternator prob..Help~!~
Old Oct 7, 2003 | 05:41 PM
dansam's Avatar
Ok 89 5.7 tpi car, only electrical mod is an electrical w/p. Worked well for a time and now the alternator is only putting out like 7 volts or so from the back of the alt when running. Checked all connections, took the alt in to be tested (tested ok) Not running; the power cable to the back of the alt is showing 12v, so is the red wire going into the top of the alt. The brown wire into the top is showing 12v when the ign is on. So to recap 12v on rear and top on both conn when ign on. I even started jumping pos to the brown wire to see if that was it, no dice. I took a jumper cable hooked it from the ned of the batt to the alt case to make sure it was not a grounding issue. Im stumped everything looks ok..... Unless the alt itself is actually bad, but I watched the guy at the store hooked it up, it was cranking out fine.....
Oh yea the right fan is now on whenever the key is on, dont know why, I unhooked it and the alt prob persists.
Im stumped if you can figure this out you are a freeking smart dude.
Dan
Old Oct 7, 2003 | 06:12 PM
Rice Killer87's Avatar
does it show any charge being made on the volt gauge while the car is running? if not,or its low,replace the alt.
Old Oct 8, 2003 | 06:20 AM
dansam's Avatar
Yup thinking the alt might be bad after all
Well When running its pushing out like 7 volts from the pos wire on the back of the alt. Im kinda bummed but I cant see what else could be wrong. Why did it test ok at the store???????
Dan
Old Oct 8, 2003 | 06:02 PM
dansam's Avatar
Well ummmmmm yea it was the alternator. I will give the dick at the parts store how much I appreciate being led down the wrong road for a whole week!!!!!!! Ok its not his fault the machine said it was ok.... so thats life.
Dan
68camaroboltz
Oct 5, 2015 01:46 PM
drt
Sep 27, 2015 04:39 PM
tommalcolm
Sep 11, 2015 03:39 PM
Pwilson59
Sep 3, 2015 08:47 PM
Thirim
Jul 30, 2015 01:29 PM
