Starting problem
Guest
Posts: n/a
OK, this will be long but I am trying to eliminate most questions up front.
<p>
Here is what's going on. The car starts fine normally when cold. When shut off after letting it run for a while(few minutes to long trips) it will not restart for a few minutes at least. Sometimes up to 15. I've got it narrowed to a fuel problem because I can get to start immediately with brake kleen. I have tested for spark and have plenty. I have tried unplugging the MAF and it would start, but only twice it did that. I have a cranking pulse on the scanner when trying to start. The coolant temp sensor is OK also. I have used Noid lights to check for injector pulse and when plugged in they did not pulse until a few seconds after cranking. I have a new ignition module, cap, rotor, ECM. I have 11.56 volts at the injector plugs. I have checked grounds at the cylinder heads and body for a good connections. I have good fuel psi, when the key is turned on it will peg to 60 or better than hold around 45, but it will not start.
<p>
Any information or trouble shooting would be great !!!!!!!!!!!!
<p>
<p>
the heat soak from the motor could be boiling the fuel in you fuel rail causing an air lock.you can warm it up and put a fuel gauge on it then shut it of and see if the pressure holds.if it doesn't that is most likely your problem.
Alex Barnes
Jan 24, 2015 10:21 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
