Springs
Old Feb 8, 2004 | 04:27 PM
red85berlinetta's Avatar
Springs
hey guys will i be able to use my stock springs for my new cam
214/224 .442/.465
the springs are in very good shape i just wanna make sure that they will still work and the springs wobnt bind up... however i think its fine since the life on this cam isnt that dramatic... o yea just wondering whats the lift stock on an lg4? thanks
Old Feb 8, 2004 | 04:59 PM
1fastformula's Avatar
Thumbs up
Here ya go my man
Camshaft Data
Lift Duration Lobe Rocker
Motor GM P/N Int. Exh. Int. Exh. Separation Arm Ratio
1985 (L69 and LB9)
305 AT 14088843 .403 .415 202 206 114.5 (115/-114)
1986 (LB9)
305 AT 14094097 .350 .385 178 194 109.0 (106/-112)
1987
305 AT (LB9 10088155* .350 .384 179 194 109.0 (108/-112)
305 5spd / 350 AT
(LB9/ L98) 14093643* .404 .415 202 207 114.5 (115/-114)
305
(LM1 Police Pack.) 14093640* .383 .404 291 202 112 (108/-116)
1988, 1989
305 AT 10088155* .350 .384 179 194 109.0 (108/-112)
305 5spd / 350 AT 10066049* .415 .430 207 213 117.0 (116/-118)
1990-1992
305 5spd / 305 AT 10088155* .350 .384 179 194 109.0
305 G92 5spd / 350 AT 10111773* .413 .428 202 207 114.5 (116/-116)
*roller cams
Old Feb 9, 2004 | 09:31 PM
can someone please tell me if my stock springs will work with the cam i stated above?!?!?
Old Feb 9, 2004 | 10:40 PM
aklim's Avatar
That is the cam spec? Does it mention what ratio RR you wil use? I believe the standard is 1.5. In any case, what ration are you going to use?
Old Feb 10, 2004 | 06:03 PM
OEM rockers which i belive is 1.5
Old Feb 10, 2004 | 06:18 PM
Re: Springs
:shrugging shoulders: No thanks for doing your legwork???
j/k
I think you should go ahead swap out the springs. Over time that cam will wear out the OEM ones with ease.
Later
Old Feb 10, 2004 | 06:44 PM
ahh i already put the springs back on
all well there in REALLY good shape... toke the whole head to get cleaned and the guy said he couldnt belive how many miles were on it... outside of the motor made it look like it was tired but we took it all apart and MAN did the person that owned it take good car.... cylinders are all very clean no carbon valves are seatted good... we relapped them anyway... whole head is in grat shape also... this thing is in this good of shape and has 170k miles.. never rebuilt either... it even had the ORIGIANL water pump and timing set well hopefully theese spring will hold out and if they start to go what will i have to look for to know when there going
Old Feb 10, 2004 | 09:26 PM
Serious bogging under a load.....You figure the springs are what open and close the valves....so if thet get worn the valves will either delay in opening and closing causing a bogging sensation. Congrats on the swap though!!!! Might I suggest using Synthetic oil....My ole L98 used to circulate the synthetic and when I opened her up (due to lean nitrous ) she was clean as a whistle.....
Later
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
9t4lt4z28
Parts Wanted
Jul 19, 2015 06:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
Catmaigne
Jul 14, 2015 05:17 PM
