speed limiter?
Old Jul 29, 2003 | 03:52 AM
etslbrown's Avatar
speed limiter?
Just curious what the the speed limiter is set at on a 1990 RS 305 TBI? my speedo does not work and it shuts down, at what speed i do not know, any help would be appreciated.
Old Jul 29, 2003 | 07:18 AM
87DJP2001's Avatar
My guess with a RS and it did not come with speed rated tires V/Z
the limit should be 115 MPH.
Old Jul 29, 2003 | 07:32 AM
TheGreatJ's Avatar
When I had the TBI305 in my '91 RS it would shut down at 115. So yeah, DJP is correct.
Old Jul 29, 2003 | 09:10 AM
Black6SpdTA's Avatar
Yup, 115 here check this out:
http://www.thirdgen.org/newdesign/tech/unlimited.shtml
-Rippin
Old Jul 29, 2003 | 04:36 PM
mikey dragster's Avatar
MY 91 TBI CUT'S OUT AT 117MPH AT 4,400RPM'S IN OD
OR AT 117MPH AT 6213RPM'S IN DRIVE.
BUT UNDER MY TBI I GOT A 350. OR RATHER HAD A 350 NOW ITS GOINT TO BE A 406.
Old Jul 29, 2003 | 05:25 PM
87DJP2001's Avatar
Who cares, the question has been answered.
Old Jul 29, 2003 | 05:29 PM
NO NO NEW QIESTION WHY IS THE PONTIAC'S LIMITER SET 2MPH HIGHER THEN THE CHEVY'S.???????????????
CHEVY CAMARO 115 V.S.PONTIAC FIREBIRD 117.
BOTH ARE TBI'S.??????????
Old Jul 29, 2003 | 05:43 PM
Fast_B4C's Avatar
I dont have a speed limiter and it says RS on my car??????
Old Jul 29, 2003 | 05:54 PM
Zepher's Avatar
Maybe cuz you have a B4C option.
It's probably 117 on both Chevy and Pontiac. Speedos aren't that accurate at high speeds anyways.
Old Jul 29, 2003 | 05:57 PM
yeah that's what i figured. there both set at `117mph.
Old Jul 29, 2003 | 05:58 PM
92BLKL98's Avatar
-Rippin
Not intended to flame anyone or third gen.org but: I am a big fan of thirdgen.org but to me the guy who wrote this as well as thirdgen.org dropped the ball on this one. Wouldn't it be a cleaner job to just remove the speed limiter in the memcal. If you have a buddy with a prom burner and the software it is very simple to do. The limit set at the factory on the cars with Z rated tires at an unobtainable 255 mph.
Old Jul 29, 2003 | 06:00 PM
Both are set at 115. At 100+ mph, speedo's arent perfect. You were probably only going 115 even if it said 117.
-Rippin
Old Jul 29, 2003 | 06:01 PM
It would be cleaner but if you don't have a buddy with the stuff, well then it's no so easy. And if you have the switch somewhere like under the dash, I think it'd be pretty cool. Either way though...
-Rippin
Old Jul 29, 2003 | 06:07 PM
Zepher's Avatar
It's easy to reprogram the TBI cars since the chip isn't in a large holder like the TPI cars and the later V6's.
I reprogrammed my friends 91 TBI Bird when he went from 2.73 gears to 3.42. He'd hit the limiter at 92mph since the ecm was still reading 115-117 due to the gears.
Old Jul 29, 2003 | 11:50 PM
Fast_B4C's Avatar
Hahaha Yah thats true
