Smog pump question
Old Feb 13, 2003 | 06:19 PM
ViperXx's Avatar
Smog pump question
I think my smog pump is about to go and someone told me I could just pull the pulley off of it temporarily and disconnect the hoses. I know about the hoses but how exactly does the pulley disengage?
Old Feb 14, 2003 | 12:32 AM
Chris Ja's Avatar
Eternal Member
Smile
You can just take the belt off. and it will be fine. or you can take the hole thing off. I took my off years ago with no problems.
Old Feb 14, 2003 | 11:59 PM
jeffsbluez's Avatar
Just for s**ts and giggles. What the heck does the smog pump do anyway? I know it pumps air into the exhaust but is that it? Can it be turned into a vacume pump for the crank case or does it already do that? Please don't make fun of me, I'm just trying to learn something.
Old Feb 15, 2003 | 12:13 AM
ViperXx's Avatar
Actually, I really don't remember what it does. I was just thinking about it and I thought it pipes the unburned fumes back into the car to be burned but then I just thought about that, thats what the EGR does right? But now that I think about it again, I don't think this car has an EGR. My other car has MPI which has an EGR but I don't think it has a smog pump. So someone correct me if im wrong, but doesn't the smog pump serve a similar purpose as the egr?
Old Feb 15, 2003 | 12:46 AM
jeffsbluez's Avatar
You should have a smog pump under the A/C pump. I think the "GM" term is AIR PUMP. You are correct about the EGR piping unburned gases back to be burned again. You should have both. My 91 z28 had both from the factory. Are you using the same tbi injection as the 305? I'm not totally sure on the tbi car though. I use to have a 91 rs and if I remember correctly it had both.
Old Feb 15, 2003 | 12:52 AM
ViperXx's Avatar
You should have a smog pump under the A/C pump. I think the "GM" term is AIR PUMP. You are correct about the EGR piping unburnt gases back to be burned again. You should have both . My 91 z28 had both from the factory. Are you using the same tbi injection as the 305?
Yes. Unfortunately when I go to do the TPI change over alot will have to change though.
Old Feb 15, 2003 | 12:56 AM
jeffsbluez's Avatar
What setupare you going to use? I have a SuperRam now and am very happy but it is a pain to install I am thinking of going t the Stealth Ram.
Old Feb 18, 2003 | 12:28 AM
Shane87Irocz's Avatar
smog pump
Hey I have a 87 iroc 350 and i took of the smog pump and blocked off the hose. i could tell a noticible hp diffrence and i also lost about 18lbs by taking off the smog pump and brackets. i have no problems with any computer codes. so i would give it a shot.
Old Feb 18, 2003 | 04:39 AM
aklim's Avatar
I have the superram unit and it is not that bad. I slotted the bolts so they could be bolted in with a small screwdriver from the top. Later I drilled out all the screw threads and helicored the runners at the bottom. When I screw the screws in, I use locktite to make sure they stick.
Old Feb 18, 2003 | 02:16 PM
ViperXx's Avatar
I haven't decided yet. I have a friend that can get me a carb setup real cheap so Im considering doing that for now and later going to TPI. Right now this TBI is killing me.. Its running like crap and I can't seem to get the IAC to work right.. the old one was seriously messed up and the book said to set the spindle to the same position, so I did, and it still runs like crap. If I set the spindle at a certain position and leave the IAC unplugged it works fine except when I first start the car up it tries to die and at an idle it idles really high.. Don't know what to do to fix it.
alphaauto
Jan 23, 2015 07:42 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
cmdeshon
Dec 27, 2014 10:06 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
