Smog delete?
Old Apr 6, 2006 | 09:33 AM
staleyracing's Avatar
Question Smog delete?
I want to take all that smog crap off my Z28. I saw on cardomain that a dude did it on his camaro. I know I need a smog pump delete pulley. I know that I can finally buy headers that dont cost a arm and a leg cause they wont have the A.I.R. crap on em. Im sure ill have some things that are going to need to be capped off. But what else do I need to worry bout? Will my ECM run like crap? Do have to get a new PROM? Anyone else done this project?
Old Apr 6, 2006 | 07:20 PM
thirdgenrallysport's Avatar
Re: Smog delete?
ive deleted all my smog/emissions stuff, but i dont run a stock ecm so im not sure how they run with all that removed.
Old Apr 6, 2006 | 10:54 PM
LesPaulGoth's Avatar
Re: Smog delete?
I took off every last bit of smog equiptment on my car, and my car runs fine, you should have no problem. And you dont HAVE to get a delete pulley, just buy a belt that is shorter and run that instead. Check out this article to help you out a bit:
http://www.thirdgen.org/serpentine
The pictures show an engine that has had the power steering pump as well, so for now, just pay attention to the text in that article. Search the internet for the correct routing, I forget mine off the top of my head, but I believe it is over the AC, under tensioner, over Alternator, Over P/S, over water pump, back under the crank, and up to the AC.
Old Apr 7, 2006 | 09:16 AM
Re: Smog delete?
thanks for help Now I can buy a set of headers without that damn A.I.R. crap on it.
Old Apr 7, 2006 | 09:49 AM
Damon's Avatar
Re: Smog delete?
I did the same thing to my 92- following the article that Goth posted a link to over on Thirdgen. It works just great. I would, however, recommend a belt that is slightly shorter than the 96.8" belt recommended in the article. Something in the 96.3-96.5" range would work better, if one is available in that length.
Old Apr 8, 2006 | 09:48 AM
fireball451's Avatar
Re: Smog delete?
I did the same as the article on TGO.
The recommended belt size worked perfect.
Just a little pricy.
Guess they were proud of that size!
Old Apr 9, 2006 | 01:29 AM
Kevin91Z's Avatar
3rd Gen Tech Moderator
Re: Smog delete?
The only smog equipment the ECM cares about is the EGR. You can remove everything else without setting a code. Keep in mind however, removing emissions equipment on a street vehicle is a federal offense punishable by a fine, jailtime, or both.
Old Apr 9, 2006 | 09:58 AM
DCJLove's Avatar
Re: Smog delete?
Has anyone seen degraded performance from removing their smog gear?
I bought my Z back in January from PA and it had ALL of the emissions gear removed. Well, long story short, I had to do a lot of work to get it back on for VA emissions testing (since I live in the city). The car actually runs better with the emissions gear on. Not sure if it is because it is carbed versus you all doing it to TPIs. Or the fact that the headers and such were still all geared to having emissions gear.
Old Apr 9, 2006 | 10:35 AM
Gord's Green Z28's Avatar
Re: Smog delete?
My car went slower with the cat removed. Put it back on and everything is better.
Old Apr 11, 2006 | 04:45 PM
S8NSW8N's Avatar
Re: Smog delete?
I removed all mine and left the pump on after gutting it and no need to purchase a new belt.
Old Apr 20, 2006 | 03:46 PM
1987IROC350's Avatar
Re: Smog delete?
My belt broke on my smog pump after my emission test last year. '87 and earlier TPI dont have a serpentine belt so you can just remove the belt. I didnt notice any change.
Old Apr 20, 2006 | 05:41 PM
Willie's Avatar
Re: Smog delete?
If any of you guys are willing to sell your smog pump and diverter valve, I'm looking for both. BUT it has to be off a v-belt system (1982 - 1987). On these years, both parts were connected with a hose and not a hard line like the 1988-92. Anyone interested?
Willie
Old Apr 22, 2006 | 10:04 PM
Kevin91Z's Avatar
Re: Smog delete?
Willie
My 91 has a rubber hose. Its only the 88 cars I have seen with the hard line for the AIR system.
Old Apr 23, 2006 | 02:46 PM
sparafucile17's Avatar
Re: Smog delete?
I also removed the SMOG stuff off my '91 Z28 and I noticed improved performance. In particular I found that the idle RPM dropped a good deal lower and the car seemed to run better on cold starts. Once it warmed up though I can't say I noticed any significant power gain.
When I did it my car was stock and I had to plug up AIR holes in the manifold as wells as stuff some JB Weld in the CAT inlent tube.
Jeff
john henry
Aug 14, 2015 08:33 AM
john henry
Classic Engine Tech
tnmotown
Aug 10, 2015 11:52 PM
colts0455
Jul 8, 2015 12:21 AM
