Shocks or Struts???
Originally posted by Zepher
Spring doesn't have to come out in the front to do the struts.
Just jack up the front and put it on jack stands, put a floor jack under the a-arm to support it, unbolt the strut from the spindle and unbolt the strut from the strut tower and pull it off.
Easy job if the bolts on the spindle aren't frozen.
Now, what about alignment? Will you shift it since you are taking the strut out?
I didn't need to do it on mine or my friends, but I guess it would'n't hurt to get the car re-aligned.
nothing is moved when changing the struts, the strut plate doesn't get touched when doing the swap.
I actually had to swap the pass side strut and spindle on my formula with my T/A since the bolts were totally frozen, couldn't get them to budge at all. 2 hour job took 9 hours.
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
