serious overheating / already used search
Old Jul 1, 2005 | 09:35 AM
v8nate's Avatar
I just replaced the water pump and radiator in my car a few days ago, and lastnight smoke just start rising out from my hood. I lifted the hood, turned it off, and coolant was spraying out of the coolant resavoir, and swelling up. Pressure kept building and building, so i quickly removed the rad cap, and all my coolant went flying 10 feet in the air until it was drained. Anyone know what this could be?
Old Jul 1, 2005 | 10:48 AM
klumb15's Avatar
Re: serious overheating / already used search
have you changed you thermostat? if your thermo is sticking closed, it'll never allow the coolant to get into the engine, therefore builds tons of pressure and goes out your radiator cap...
Old Jul 1, 2005 | 06:58 PM
Marc 85Z28's Avatar
Anytime you post a technical question it helps to know what we're working with...
Old Jul 1, 2005 | 08:01 PM
rdrokit's Avatar
I' thinking thermostat to ,Are your fans kicking on? is the air Dam put back on?
Old Jul 2, 2005 | 01:10 AM
AutoRoc's Avatar
Yeah what year car/engine, etc..
Maybe you got a water pump that turns in the wrong direction?
Timing could be WAYYY off.
Thermostat is obvious also. Removing it and testing it in a boiling pan of water can basically solve that.
Goodluck!
Old Jul 3, 2005 | 10:00 PM
Kwiksilverz28's Avatar
Thermostat in backwards?
Old Jul 4, 2005 | 11:14 PM
rollingstock's Avatar
im havein the same problem.. upgraded waterpump, newer rad., new thermostat(even tryed without one), i have the fan hot wired to a switch, so i know its on.. even new senosers. still runing 240+
i have a 89 z28(305)
i duno what else todo but upgrade the rad. and fans(which i dont have money rightnow)
Old Jul 5, 2005 | 04:56 AM
v8nate's Avatar
Sorry I haven't been on to reply. I have an 88 RS 305 TBI. Turns out its the head gasket. I don't really wanna pay some jerk to put in a headgasket in an old 220,000 km 305, so im doing a carb'd 350 swap. I've found a rebuilt 350 bored .30 over, also comes with a 350 turbo trans.... Im gonna see if its possible to hook the 350 up to my 5 speed, if not, i'll be going over to the turbo trans.
I'll keep ya's updated.
Mikes 1994 z28
Oct 10, 2015 07:55 AM
autoxr166
Sep 25, 2015 04:21 PM
Fatdog2
Sep 16, 2015 11:04 PM
Sep 11, 2015 09:44 AM
Pwilson59
Sep 3, 2015 08:47 PM
