Running numbers...
Old Aug 18, 2003 | 08:32 AM
KnightRider350's Avatar
Running numbers...
A buddy of mine just pulled the numbers off of my engine and heads, and I was curious where I could run the numbers and get the info on them.
Engine: 3782680
Heads: 12529093
...Would be nice to finally figure out what's REALLY under my hood.
Old Aug 18, 2003 | 02:26 PM
Black6SpdTA's Avatar
I don't know man. I checked www.Mortec.com they've had every other number I've looked for
-Rippin
Old Aug 18, 2003 | 03:12 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
you must have gotten the numbers slightly wrong
The closest I found to your block was a 3782870 which is a 62-67 327 block.
ANd if you got the last 3 didgits right on the heads, it would be 86-88 350 heads. Im pretty sure that head numbers never repeat the last 3 digits. Make sure you at least get those right.
If the numbers on the back of the block are hard to read look at the code, on the front of the block right below the passenger head. It should have a series or letters. Give me the last 3 letters and I can tell you what it is.
Iamherefornow
Jan 26, 2015 04:57 PM
Amshnock
14
Jan 18, 2015 11:47 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
