rocker arms
Old Dec 11, 2003 | 08:47 PM
StealthElephant's Avatar
rocker arms
Do these things really add any horsepower? CC claims 25HP but I doubt that....I mean....does it really matter? Cause rocker arms are easy to switch....but 300$ is kinda deep.
http://store.summitracing.com/partde...N%2D10750%2D16
Old Dec 11, 2003 | 10:29 PM
Black6SpdTA's Avatar
I don't think you'd really see 25hp unless you start with 20 year old, corroded, rusty, old oil goopy stamped arms. You might see 10-15hp. Figure (with a 10hp gain), that's $30/hp. You can find some for around $200. Look on eBay. They're definitely a good thing but sure are expensive.
Old Dec 12, 2003 | 01:58 AM
97WS6SCharged's Avatar
On a big block, I'd say that 20-25 hp is not unheard of, however on a small block, it's more like 10-15 if you've got good heads.
Old Dec 12, 2003 | 02:13 AM
Error404's Avatar
wouldn't 1.6 rockers give a bit more power? I mean, it's a tad bit more lift, right?
Old Dec 12, 2003 | 02:58 PM
79TTCAMARO's Avatar
Go with a set of 1.6 toller tip rockers. You get the best of everything....More power, Less wear,Less money and you dont have to change your valve covers. You will never feel the power difference between full roller rockers and roller tip rockers. The only time I would recomend full rollers is if you plan on running a high lift cam. Also Full roller rockers will have to be adjusted eventually. Hope that helps!
Old Dec 13, 2003 | 11:46 PM
Generally, increasing the rockers ratio by .1 adds up to being about .030" extra lift, and maybe a degree more duration. Yes, they will give a bit more power because the valves will be open slightly longer than with the 1.5 rockers. Will they give you 15-20 hp every time? Probably not.
You also need to make sure you valve springs won't bind when going to bigger rockers.
13qtr
Oct 28, 2016 08:11 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
Z Power
Sep 19, 2015 11:19 PM
