Ring and pinion carrier??
Old Jul 12, 2003 | 08:32 PM
slayer6x6's Avatar
Im looking to order new gears for my car, but do i get them for a 2 series carrier or a 3 series carrier? How do i tell which one i have?
Old Jul 12, 2003 | 08:48 PM
slayer6x6's Avatar
BTW, there is an rpo code GU2 which is the 2.73 axle ratio, and im going to a 3.73 ratio.
Old Jul 12, 2003 | 10:29 PM
TheGreatJ's Avatar
You have a 2 series, and you need a 3 series to run 3.73's. You can get 3.73's with a thicker ring gear to fit a 2 series carrier, but you have to ask for them specifically and a lot of places don't have them.
Old Jul 13, 2003 | 09:22 AM
slayer6x6's Avatar
So then i could use these gears without changing the carrier?
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2422588792
Old Jul 13, 2003 | 09:58 AM
GMTech's Avatar
I won't garuntee they fit, but going by his description, yes they will. They are described as being 3.73s for a "2" series carrier which is what you need.
Old Jul 13, 2003 | 10:52 AM
TheGreatJ's Avatar
Agreed. They will fit ACCORDING TO WHAT HE SAYS. You'll have to go on trust that he's not an idiot or scammer. However, FWIW, in the pic it looks like the ring gear is thicker than normal. That would indicate a 2-series gearset.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
mmf_1013
Sep 12, 2015 08:56 PM
blaze309
Sep 8, 2015 05:27 PM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
