retro fit hyd. lifters for 87+ sbc
Old Dec 15, 2003 | 07:49 AM
oil pan 4's Avatar
Does any one know where I can get retro fit hyd roller lifters(not off set) for my 89 small block for less than $550?
Ok I'll even think about solid lifters if ther a real deal( I have delwest titanium 1.460'' retainers and del west super 7 locks to use).
Just want rollers so I can free up 15-20 ft.lb. (could become 20hp easy)through out the hole rpm range.
Old Dec 15, 2003 | 07:09 PM
kmook's Avatar
Advanced Tech Moderator
Recomendations on where to get general parts should be posted in a difrent forum, like a gen spacific one.
Moving to 3rd Gen Tech. Thanks.
Old Dec 16, 2003 | 01:06 PM
gs400tx's Avatar
try competion products or herbert perf
http://www.primediapowerpages.com/cg...0216&2D1007369
or
http://www.herbertperformance.com/cg...e2.asp?cat=430
(lame herbert page can't be navigated for all vendors very well).
The speed pros come out $376.. not bad
Speed-Pro SEA-HT-5000RA
Reduce friction while increasing horsepower and fuel economy. Chevrolet: 262-400, Retro-fit, replacement hydraulic roller lifters Your valves will open more quickly from a fully closed to a fully opened position with a roller setup, compared with using conventional flat lifters. When you use these lifters, you will notice higher performance, quieter engine operation, and more horsepower. These lifters also provide proper vacuum and idling capabilities. Sold as a pair.
Product Line: Speed-Pro Hydraulic Roller Lifters
Material: Steel $46.99
dfarr67
Apr 10, 2015 07:44 PM
CARiD
Jan 14, 2015 04:00 AM
NewsBot
Jan 8, 2015 11:29 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
