Question on Holley Stealth Ram?
Old Jul 13, 2005 | 08:01 AM
vodoo-chile's Avatar
Quick question for anybody with the Stealth Ram. My brother has a 92 Z with a built 355 (+ supportting mods) as well as a 12# ATI. Now, he has a blown headgasket and we have been toying around with the idea of swapping on the Stealth Ram. Is it as good as tehy advertised, with a low loss of low end trq but much better topend or is his Big Mouth base + TPIS runners + ported plenum just fine? I know it is going to be subjective to an extent but, I want to make sure I am only going to be doing this once. Also, his heads were milled when he had the motor originally built and we will have to have the new intake milled to match but, is the rest of the install just a plug and play type scenario? Thanks for any and all input,
Kyle
Old Jul 13, 2005 | 08:54 AM
sk8runeg's Avatar
Re: Question on Holley Stealth Ram?
The stealth ram with allow for a wider powerband, whereas the TPI setup will be good for lots of low end torque but will drop off quicker and have a much shorter powerband.
Old Jul 13, 2005 | 12:37 PM
klumb15's Avatar
i think you would see a pretty good gain if you guys switch to the stealth ram...also sounds from the amount of Aftermarket TPI stuff, he could sell it all and probably pay for the stealth ram...also the stealth ram will accompany the blower a lot better also, because at higher RPMS you'll be able to turn that blower more, pushing that much more air in...what else does he have done to it? heads/cam?? you'll loose very little low end torque, because the blower will comensate more over a N/A engine...i think HSR would be a great investment...i totally love mine..it feels awesome when i get into my cam's powerband, its like the car just wants to GOOO now...its amazing...
Old Jul 13, 2005 | 12:39 PM
klumb15's Avatar
also, why did he mill his heads if he was adding a blower??? that was dumb, you want lower compression with a blower/turbo...does it run alright? your chamber pressure has to be way up there...
Old Jul 13, 2005 | 04:20 PM
The shop that built the motor built it for a blower and compensated with the correct pistons, head gasket, etc. It should be at about 9.0-1 compression. Of course, I haven't verified this presonally but trust the shop, as the motor has lasted about 3 years with only te head gasket being a recent problem. I agree with the rpm range for teh blower and HSR combo over the TPI. As far as othwer mods, he has a cc305 on a 114lsa, AFR heads (untouched other than milling), built 700r4 with 2400 stall, 1 3/4 headers (mids), 3" CB exhaust, supporting ignition, custom tuning, and of course the blower, all on a sesame seed bun. What else is needed for the swap on a 92 for the HSR other than the hard parts (intake and plenum)? Thanks for any input?
Kyle
Old Jul 13, 2005 | 04:26 PM
91-Z28-L98's Avatar
I believe you will need a new fuel rail and some new connecting fuel lines. I would get the fuel rail from Holley with the adjustable fuel pressure regulator.
This sounds a lot like the setup that I want to get down the line. How much Hp/Tq is he makeing?
Old Jul 13, 2005 | 04:41 PM
klumb15's Avatar
yes you will the need the intake itself, then holley's fuel rails, then custom made fuel lines...just order SS braided ones, its about 120 for the lines, otherwise you can go the rubber route and save ya some money..the intake is 300 new, fuel rails are 220 new i believe..then you can run your stock TB if ya want, i would suggest a bigger one if you don't alreayd have one...you can go to stealthram.com i believe it is, and it tells you all the parts you need...its like 620 for the hole swap..
Old Jul 13, 2005 | 05:26 PM
I forgot he already has a 52mm tb. Thankyou for teh link. I'll check it out tonight.
Kyle
Old Jul 13, 2005 | 05:44 PM
Zepher's Avatar
Takes 1 day to do the swap on a stock TPI car, this includes yanking everything off and gathering up all the parts.
For the fuel lines, I was going to use adaptors to adapt the hard lines to -6AN fittings but noone had them in stock, so I had a local shop cut a part of my stock TPI hard line and braze on a -6AN fittings so that I could attach the stock rubber lines to the SS braided lines.
Stock TPI
HSR
Old Jul 13, 2005 | 07:02 PM
klumb15's Avatar
yea summit has the correct connectors, ones a 14mm and the other is a 16mm i think...i like the hardlines straight to the SS lines, because its real visible right there and you can see the fittings and everything...just kinda shows it off a little bit more, cuz afterall it is 120 for SS lines!!
Potent77
Mar 16, 2022 12:13 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
LT14LIFE
Feb 9, 2015 09:35 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
