Quarter mile times for '87 formula
Old Jan 25, 2005 | 12:44 PM
kbog54's Avatar
Hi, i was wondering if anyone could give me some rough times for my '87 formula 350 tpi ws6 auto.
Mods:
Ported intake plenum (upper and lower)
Hi flow MAF
cold air intake
28lb. injectors
Comp hydraulic roller cam- .515/.525 112LSA
titanium double valve springs
Comp cams double roller timing chain
ported aluminum l98 heads freshly rebuilt
1.6 roller rockers
Full MSD ignition- msd6al
splitfire plugs
hedman long tube headers 1 3/4primaries 3in collectors
summit x-pipe dual 2 1/2 in exhaust with dynomax bullet mufflers
2200 stall, b&m shift kit
subframe connectors, strut tower brace, aluminum driveshaft.
3.42's with posi
bfg drag radials
car weighs in at 3000lbs at a local scale and hooks right up at the stall and goes
any estimates on times (i know each setup runs differently but i just need a rough estimate)
thanks.
Old Jan 25, 2005 | 12:50 PM
teke184's Avatar
Re: Quarter mile times for '87 formula
13s....
mostly due to the TPI running out of steam on the top end.
it's so highly modded it is almost impossible to tell what it will run
Old Jan 25, 2005 | 09:04 PM
89TramsAmGTA's Avatar
With your car weighing 3000 pounds you should be able to run the high 12's. As was stated above there are a lot of factors that play into how fast your car will go. I assume you have a custom eprom that is dialed in pretty close.
Old Jan 27, 2005 | 10:29 AM
kbog54's Avatar
yes, i had a custom eprom burned for it, wish i would have paid the extra 200$ to get a dyno tune as well.
thanks guys
F'n1996Z28SS
Aug 23, 2023 11:19 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
Jazsun
Dec 29, 2014 12:14 PM
Z284ever
43
Jun 27, 2002 10:36 AM
