Proportioning valve
Old Mar 21, 2004 | 09:31 PM
BPS's Avatar
BPS
Question Proportioning valve
I just got a 3rd gen proportioning valve (all disk brake model) to put onto my 4th gen as I'm removing my ABS.
The valve has 5 inlets (2 in, 3out). However none of the inlets are marked and I can't find a diagram.
I see there are 3 inlets on one side and 2 on the other - is the set up that the 2 line from the master cyl goes to the side with 2 inlets and the other side feeds the calipers?
I'm assuming the larger diameter inlets are for the rear brakes.
Can anyone confirm this.
thanks
Old Mar 21, 2004 | 10:28 PM
TheGreatJ's Avatar
On the side with 3, you'll have 2 straight and one angled, with a sensor between the straight ones. The straight one by itself is the rear wheel inlet, the straight one by the angled one is the front wheel inlet. The angled port is the right-front outlet and the port on the opposite side of that is the front-left outlet. The port on the 2-hole side that sticks out farther is the rear outlet.
Keep in mind, the forwardmost port on the master cylinder is actually for the rear brakes.
If this only confuses you more, shoot me an email. I can take a digital pic and label it, then email it to you.
Old Mar 21, 2004 | 11:06 PM
BPS's Avatar
BPS
Thanks - that is very clear - glad I asked as it is not obvious!
RUENUF
Mar 13, 2016 03:37 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RX Speed Works
Jul 24, 2015 02:25 PM
HectorM52
Parts Wanted
Jul 19, 2015 08:55 PM
