probelms with idle on 92 z28
Old Jun 29, 2005 | 10:57 PM
92brZ's Avatar
i purchased a 1992 z28 two weeks ago and just started to have problems with the idle. you can head the motor rev and them drop in rpm's. also u can watch the tach jump. maybe the iac ? not sure
Old Jun 30, 2005 | 02:42 AM
billyhoss's Avatar
Re: probelms with idle on 92 z28
i would check for a vac leak or gasket leak
Old Jun 30, 2005 | 05:28 PM
91-Z28-L98's Avatar
If it revs then drops once on startup, thats normal. If it continually changes RPM for no apparent reason, then you have a problem. Let us know which is going on.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Noenav
Mar 1, 2019 07:38 AM
bfmv13trivium
Jan 14, 2015 09:57 AM
A's 91 Z28
Jan 11, 2015 10:58 AM
