Plug wires question
Old Mar 8, 2006 | 03:21 AM
Tremo's Avatar
Plug wires question
Yo guys, If I install a new aftermarket hot coil (MSD 8226) on my car, will it blow through the stock 7mm ignition wires? I was going to eventually go with 8mm spiral core wires, but will I have to do that along with the coil swap, or can it wait a while? Thanks.
For wires I was thinking about Accel 9033 set. Opinions?
Old Mar 8, 2006 | 07:59 AM
LesPaulGoth's Avatar
Re: Plug wires question
It won't "blow through", but those stock wires are going to carry that nice spark from that MSD coil pretty badly. I had an Accel coil giving spark to 8 stock wires for a few years (before I owned the car), and they were fine (until I got new headers =/ ) It would be in your best interest to just get new wires that are 8mm-9mm.
As far as those wires you mentioned, they seem a little pricey to me, you can find cheaper Accel's that are just as good, or MSDs or Taylor wires.
Old Mar 8, 2006 | 09:18 AM
NastyTA's Avatar
Accel wires are awful. Oil and heat resistance stink and their boots aren't the best either. They just don't last like they should. I've never had a problem with MSD or Moroso wires. I like the Morosos better, the boots aren't as big so you get better header clearance.
Old Mar 8, 2006 | 03:54 PM
Tremo's Avatar
Thanks guys for the info so far. I've done a bit more digging on this and have come up with a couple custom-fit alternatives. I don't have headers, BTW. What do you guys think of the following two sets? Both are 8mm silicone with spiral cores, both custom fit for the engine. Both cost about the same, $45 or so from Summit.
Moroso 72538
Taylor 74611
Opinions? Thanks again!
Old Mar 8, 2006 | 06:45 PM
NastyTA's Avatar
custom fit wires are always too long and look like crap draped all over the motor IMO. Cut to fit is the only way.
Old Mar 8, 2006 | 09:07 PM
Clearance issues? I'd like to know what set of wires and headers you have because as long as you have a brain, it's easy to rout them so they are not touching the header.
Old Mar 9, 2006 | 09:19 AM
V8Rumble's Avatar
I'm using a set of "cut-to-fit" Taylor wires (necessary because of my SLP headers), & they seem to work well for me.
BTW, you guys DO know that "7mm", "8mm", etc. only designate the thickness of the insulation, don't you? It has nothing to do with the thickness of the actual conductor...
Old Mar 9, 2006 | 01:51 PM
Tremo's Avatar
Yes, I know that the 7mm, 8mm, etc means the insulation thickness. That was one of my original questions, is a 7mm insulation enough for a hot coil, or will it arc through? I believe the hot coil will not be an issue for the 8mm or larger jacket.
Any replacement wires I put on the car will definitely be spiral conductor core with the 8mm silicone jacket. Those plug boots on the Taylor wires look beefy, and like you can get a good grip on them for removal come plug change time. Comments?
Old Mar 9, 2006 | 10:16 PM
Like I said before, no, the coil will not cause the 7mm to break open, the previous owner had an Accel coil in the ignition for 5 years, and they were fine, until I got new headers and one wire got burnt through. However, I would suggest 8mm wires for you if you are getting aftermarket ones anyhow...besides, like I said before, MSDs, ACCELs, or Taylors will help to carry that hotter spark.
Old Mar 10, 2006 | 09:07 AM
NastyTA's Avatar
I was talking about the size of the boots. If you're using straight plug heads and a tight header, the bigger boots will touch.
I've got a brain
Old Mar 10, 2006 | 01:38 PM
Tremo's Avatar
Yo Nasty, nice lookin' motor. Neat job on the wires.
Yo LPGoth, you really have one of those black gothic Les Pauls????? Are you a goth? I have a 70s era Les Paul Special, tobacco sunburst. I alternate between that and my Strat. The Strat cuts better at gigs, the LP sounds phatter.
Iamherefornow
Jan 26, 2015 04:57 PM
Jazsun
Dec 29, 2014 12:14 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
