please answer quick question on 700r4 rebuild
Old May 30, 2003 | 07:10 AM
  #16
Nitromethane's Avatar
Oops almost forgot about the B&M Torque Arm Mount kit for a TH350, $79.99 Jegs part# 130-30299, unless u buy a $375 spohn torque arm that comes with the crossmember And if you can find a junk yard driveshaft off a 3rd gen with a 2004R transmission then you can use that for the TH350 also.
Old May 30, 2003 | 12:00 PM
  #17
aklim's Avatar
I got mine rebuilt by www.rosslertrans.com and they came recommended by Lingenfelter. Their tranny lasted 3.5 years behind my 383 with me beating on it before needing a new sun shell gear or whatever it is.
They took my stock 700R4 and rebuilt it to shift at a higher point and with a shift kit all in it.
Old May 30, 2003 | 07:10 PM
  #18
Changing shift points is just a matter of changing the springs n weights in the governor, should try and get shift points around 200rpm past your peak horsepower for a smooth accellaration - im sure you've got yours setup correctly, but just for those who don't know - there's people running around with 4500rpm peak power saying "yeah my car revs out to 5800rpm!" just cuz their shift points are way too high - so they have 1300rpm of "dead revving", then when it finally shifts, the car starts to pull again.
Old Jun 1, 2003 | 01:32 AM
  #19
Pro Built Automatics's Avatar
Use the 1988-early1993 cores only. They come with the bigger style sprags, forward accumulator, and 30-spline input shaft.
alex5366
Feb 17, 2015 09:07 AM
94Form
Feb 10, 2015 11:23 PM
heavenly_six
Dec 10, 2014 12:23 AM
redzed
Sep 4, 2002 06:22 PM
Brent94Z
Mar 21, 2002 04:44 PM
