performance chip skeptics/proof
Old Jul 2, 2003 | 11:47 AM
kevin 2.8's Avatar
im looking into getting a hypertech chip but i have ran across alot of skeptical information while doing research, i was wondering if anyone has done dyno or has any personal experiences with chipping their car. im only considering it because i have a chip available to me for about 1/4 the usual cost
Old Jul 2, 2003 | 11:54 AM
87DJP2001's Avatar
As long as you are not paying full price for the Hyperjunk chip. I would go ahead and install it if you have a basic stock engine. But note! its NOT going to give you screaming performance. I do use a aftermarket Chip from Fastchip.
Old Jul 2, 2003 | 12:02 PM
kevin 2.8's Avatar
did you notice anything.. say like in numbers off your 1/4 or gas milage or anything
Old Jul 2, 2003 | 12:07 PM
87DJP2001's Avatar
Only difference from the Stock GM 350 chip I used to get up and running, was that it changed the shift point to the better & turned my fans on early until 35 MPH.
Old Jul 2, 2003 | 12:37 PM
angel71rs's Avatar
I know that it added more timing, because after the chip install, I was no longer able to run midgrade gas. Premium only. Being able to go to a 160 stat was a big help; the 'bird always ran better at lower temps. I never took the car to the track before the chip/K&N/Flowmaster changes, but after it did run a best of 15 flat. Local track is at 4,100 ft, so about a 14.3 corrected.
This is on an 89 Formula 350 twin cat. BTW, chip was a gift. Wasn't planning on installing one, as the 'bird is my daily driver. K&N was cause I'm too cheap to buy filters every 3 months (dusty out here), factory muffler made no performance noises, so it had to go.
Old Jul 2, 2003 | 12:44 PM
Jim85IROC's Avatar
You can achieve the same results as a hypertech chip by advancing your timing a couple degrees and running premium fuel.
Old Jul 2, 2003 | 01:35 PM
HardDriver's Avatar
I put in the second level Hypertech chip and I did notice a slight increase in "seat of the pants" performance. This was after installing headers and cat-back plus cold air. Was it worth the full price I paid - no, but a 1/4 of the price and it is so easy to do - why not?
Old Jul 2, 2003 | 06:49 PM
kandied91z's Avatar
i'm so sick of chips.....hypertech and jet are worthless for their price. even my tpis chip isn't the greatest.
onto DFI!
Old Jul 2, 2003 | 07:45 PM
TheGreatJ's Avatar
IMHO changing your chip isn't worth it unlees you're custom tuning it for the specific car. If you can get a HyperTrash for next to nothing then go with it, just to turn the fans on earlier. But don't expect any real gains.
May 15, 2015 10:43 AM
96SilverRam
May 5, 2015 09:56 PM
Fatdog2
Mar 31, 2015 06:50 AM
Jonnybegood
Parts Wanted
Feb 10, 2015 07:50 AM
Jul 4, 2005 05:00 PM
