People with aftermarket seats-inside-
Old Sep 27, 2003 | 01:57 AM
Irocvette355's Avatar
Arrow People with aftermarket seats-inside-
Well my cousin just gave me his new R-1 RSR style seats.
I test fitted them, and the factory brackets from my camaro line up and every thing, but it makes the seats sit up too high. The reason is because i have to use spacers top make the factory brackets fit the coutour of the new seats.
Anyone know where i can get seat brackets that will fit to the contour of the bottom of the R-1 Seats? They have a slight upward curve in the front.
Old Sep 27, 2003 | 10:53 AM
funina91ss's Avatar
If you got the brakets working then leave it like that. My Targa RS seats sit up higher than the stock ones did. I got the brakets from carbua too. I dont like the brakets too much they only lock on one side and when you hit the breaks the seat moves a little.
Just enjoy the new view. You get to see alot more sitting up that high.
Old Sep 27, 2003 | 10:56 AM
lordmetalz28's Avatar
this is not safe if you have t tops. just imagine a piece of shrapnel coming at you at highway speeds and it shaves a piece of your skull off. id do it right if you flip over your gonna grate your skull across the concrete youll totaly be brutalized alive. i would defiently get it done right
Old Sep 27, 2003 | 11:01 AM
funina91ss's Avatar
I have t-tops and my head dont stick out of them. If you look at it you wont see the diffrence in hight.
Old Sep 27, 2003 | 11:51 AM
crazyjoe's Avatar
I'm in the same boat, and I have Corbeau CR1's. I got the brackets straight from them and it raised the seats up quite a bit. I also have a t-top car and I'm 6'3" and my head doesnt stick out of the tops. I've come to like the new view and ride height, I would probably feel too low if I went back to stock!
Joe.
Beave2780
Sep 23, 2015 12:37 PM
Bxlt1
Sep 10, 2015 08:16 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
