Pedal Assembly
Old Jul 30, 2007 | 12:19 PM
69MaroConv's Avatar
Pedal Assembly
Will a 3rd Gen Pedal Assembly work with a T56 (93-97 LT1 type)?
Old Jul 30, 2007 | 04:41 PM
Dave89IROC's Avatar
IIRC, yes, if it is a manual pedal assm., you may need to play with the hole in the firewall
on a similar note, 4th gen manual pedals will work in a 3rd gen as well
Old Jul 31, 2007 | 09:37 AM
69MaroConv's Avatar
Sorry about that, yes the Manual Pedal Assembly.
So 3rd or 4th gen Manual Pedal Assembly will work on an Lt1 style T56. Sweet!
That's plenty of years to find one.
Old Aug 1, 2007 | 03:07 PM
mdenz3's Avatar
If you use third gen pedals with a 4th gen master cylinder the clutch engagement will be very high. The 3rd gen master will work with 4th gen slave and line and will correct the clutch engagement point for the thirdgen pedals.
Z Power
Sep 19, 2015 11:19 PM
Str8hp
Parts Wanted
Aug 25, 2015 06:03 PM
Dams76
Aug 20, 2015 08:28 AM
Jlo
Jul 29, 2015 03:52 PM
surreybrad
Jul 5, 2015 10:36 PM
