parts
Old Dec 18, 2003 | 10:42 AM
Tim89Rs's Avatar
parts
Well i didn't mean to make a new post, but im a newb, sorry
Well if you missed my last post, im trying to build up a 350 TPI system.I just need a general idea on what im building and part costs before i get myself into this.
Anyways..... I found a complete Holley Stealth RAm MPFI kit from www.summitracing.com designed to handle 385-480 horsepower, including 30 pph injectors(im thinking throttle body is included, but it didn't say, it costs$2,281 though). I guess i'll just buy the heads separate. Also found a holley adjustable fuel injection regulator(from 35-65 psi) for $135.95. I've heard vortec heads are nice, but can they handle close to 500 horsepower??MAybe with a port and polish?? Any more suggestions??
thanks,
TIm89Rs
Old Dec 18, 2003 | 02:16 PM
Black6SpdTA's Avatar
Re: parts
thanks,
TIm89Rs
Stealthram--about $600 for everything. You're looking at the wrong kit. The HSR unpolished is $300, fuel lines are 200 and little fittings and stuff. You're looking at the kit for installing it into a hot rod or something.
Vortecs can't be mated to a HSR without machine work, I'm not even sure it can be done then. Check out Pro Toplines, they're cheap and good flowing heads. That's if you are on a budget, if not, get some AFR 190/195.
Don't forget about a cam too (CC305's work well in these apps).
Stealthram- 300
Fuel lines- 200
Fittings/Hoses- 100
Injectors- 200??
AFR 190's- 1200
Cam- 200
Gaskets/Machine Work/little stuff etc-500
Custom PROM 3-400???
So around 3k for a solid 12sec 3rd gen.
-Corey
Old Dec 19, 2003 | 08:09 PM
blackztpi's Avatar
no, the stealth ram will not fit on the vortech heads at all that i'm aware of. i used the cc305 cam, afr 195's with bowl job, and 26lb injectors with 52mm tb. made around 400 rwhp consistantly. about the same in torque.
Old Dec 19, 2003 | 10:31 PM
97WS6SCharged's Avatar
Best bet would be to use just the HSR manifold. The whole setup can be had for ~$600 bucks. The one for $2k+ includes a fuel pump and a stand alone, programmable computer. Basically, get the manifold and use a stock TPI computer with a custom chip. As far as heads go, the 200cc Protoplines work well, AFR 195's are also good, or Dart iron heads are also good.
HectorM52
Jul 30, 2017 11:46 AM
novaiiman
May 15, 2016 11:36 AM
oldschool
Feb 9, 2016 09:21 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
