Only Right Wheel Has Power...
Re: Only Right Wheel Has Power...
Originally Posted by 87DJP2001
No 3rd Gen car came stock with a Limited Slip (aka posi) it was a extra cost option. RPO G80 is for a Limited Slip and on certain cars it was required but you still paid extra for it.
It could be had with any stock gear ratios if special ordered.
There are tons of thirdgens running around with from the factory limited slip units.
Originally Posted by iansane
What? You say in the same sentence you can't get and you can get a limited slip unit?
i got an 87 iroc...it has posi....no extra cost.
1987 IROC
350 crate motor
3.42 gear POSI
flow tech headers
stock y-pipe, modified
3 inch system, no cat.
650 holley double pumper
lotta other stuff....stock
stock rims w/ 235 55 16 STREET TIRES
700 r-4, stock converter
run 13.40@104mph on those same tires with a 2.15 60 foot
who says you gotta spend alot of money?????
1987 IROC
350 crate motor
3.42 gear POSI
flow tech headers
All I said was it was a extra cost option and NOT standard.. Also that tons of 3rd gen cars with a Limited Slip just means the original owners paid extra for it.
That's....****ing...obvious. I just bought a new tahoe, it came with a towing package and autoride. I paid extra for it. Does that mean it doesn't come stock? No. It just means it's an option. Doesn't mean I ordered the truck that way, it was on the lot with all those specific options.
He is saying that since it was a cost option, it wasn't a standard item and you can't really say what car to look for to get a posi rear end from.
Example. if you want WS6 springs and sway bars, only the Formulas had them stock, the Trans Am's had an option for them so if you get the bars from a Trans Am, it's not guaranteed to be WS6 parts but if you got them from a Formula, they are.
I think the breakdown in communication happened because you said they didnt come "stock." So depending on what you consider stock, its easy to take that the wrong way. Stock could mean "base model with no options" as you are saying, or it could mean "came from the factory this way" like iansane is saying (and also happens to be the way I see it). But it dosnt really matter anyway, no need to argue about it. What came "stock" in any way you define stock dosnt always mean thats whats actually on the car since they are all 10+ years old. What matters is taking the cover off and checking if there is any doubt in the owners mind. I've had to do this myself when making junkyard runs.
30th Anniv Z28
Aug 1, 2015 10:39 AM
jasonduaine
Jun 4, 2015 09:29 AM
