oil press dropping off
Old Oct 30, 2004 | 01:00 AM
transxtreme's Avatar
Heres the deal fellas,
I installed an aftermarket mechanical oil press gauge. Has anyone put a t fitting on the block for the aftermarket one so the stock one would work also? i dk if it will clear i have the edelbrock TES headers. Any one done this yet? Thanks in advance.
Old Oct 30, 2004 | 01:17 PM
aklim's Avatar
Re: oil press dropping off
What are you trying to do? If you are doing testing, forget the stock one for now.
Old Oct 31, 2004 | 11:29 PM
No I want to run both the stock and the aftermarket gauges because i dont want the stock one to sit around like a limp ****. I just want to know if anyone used a t fitting and ran both or if its not possible.
Old Nov 1, 2004 | 12:32 AM
raul.garcia's Avatar
Bit different, I ran a 1/8" hydraulic line from the port behind the driverside head to a remote manifold near the purge canister.
The manifold feeds the oil pressure sender, manual gauge, and oil pressure switch for the fuel pump.
Old Nov 3, 2004 | 10:55 PM
aklim's Avatar
If they all are off the same hole in the engine, pressure should be constant.
Dmonty
Jun 2, 2015 11:19 PM
KYWes
Apr 15, 2015 07:28 PM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
!!!TED!!!
Aug 27, 2002 05:41 PM
