O2 sensor hole on Hedman Street Header?
Old Aug 20, 2004 | 06:01 PM
Randy Capone's Avatar
Is there one on those type of header?
Old Aug 23, 2004 | 11:47 PM
90rocz's Avatar
Re: O2 sensor hole on Hedman Street Header?
You can get "weld-on Bungs" for O2 sensors to install on anything for about $8-10.. Any muffler shop can hook you up cheap..
Old Aug 24, 2004 | 07:05 AM
Well, that's ok. Anyway, I'm gonna order the hedman Y-pipe, and there's the hole in it!
Old Aug 24, 2004 | 11:47 AM
88Irocker's Avatar
Is the O2 sensor reading affected if it is moved from the header down to the Y-pipe where the exhaust may be a few degrees cooler?
Will that affect when the car goes into closed loop?
Old Aug 24, 2004 | 11:51 AM
Good question..., but actually, it's only about 6 inch or less farter then the original emplacement of the O2 sensor...
Here's a pic... Hedman Y-Pipe
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
Jul 4, 2005 05:00 PM
