Not starting after tranny swap
My 86 Iroc 305 TPI decided not to start after I put a new transmission in it. Theres spark theres gas...and its cranking. All the emission crap is plugged in. Does anyone have any ideas...Im ready to take it to a shop and let them deal with it. Is there anyway I coil could give weak spark maybe?...Im stumped
...Please Help!!!
Thanks ahead of time,
Easyrider
...Please Help!!!Thanks ahead of time,
Easyrider
Re: Not starting after tranny swap
Why would the ground wires come out? They are attached to the head and not the transmission.
The only electrical connections a 700r4 has are the TC lockup, and the Speedo cable if you have VSS. Other than that its the TV cable, and coolant lines.
The engine should fire up even with no transmission bolted up. How are you determining if the engine is getting fuel? Spark is easy, but are the injectors fireing? You can have fuel pressure, but if the injectors don't fire that won't mean anything.
hmm, i just swapped in a new trans and headers and some other stuff and mine fired right up. Did you plug in the plugs for ignition module on the back of the distributor? Theres 2 plugs.
did you check
the coil wire
the plug wires
battery cables
ignition module plugs
Thats all i can think of tonight, i just got her done and we are drinkin to celebrate so im short minded now. Good luck.
did you check
the coil wire
the plug wires
battery cables
Yeh I pulled the distributor to get to the two top bellhousing bolts. Plug wires are new, Battery is good, it has spark...i would check the coil but Ive never heard of a coil giving weak spark...as far as I know they are either good or bad..I could be wrong
I checked the timing a couple of times...maybe the distributor is off by a tooth it sat flush two ways and I tried it both ways...is that what you mean by "phased"?....Im gonna check the timing and spark again...maybe im over looking something
Sergio
Jan 27, 2016 04:27 PM
importkiller94
Jan 17, 2015 09:03 PM
