Nice Suprises found during L98 extraction
The motor is so close to coming out. Cherry picker is hooked up and everything. One exhaust mount and she's good to go. While taking apart the car to get out the L98/700R4 combo, I found some things...
Aluminum DS 3.27 9-bolt Posi rear That's sweet. I'm excited :) The DS will fit in my RS with T56 just fine right? I'll be updating the site tomorrow afternoon with pics and a brief write up. www.cardomain.com/id/sixspeedinstall |
Yeah, it'll work just fine.
sweet dude
Yea, that will bolt right up no problem. Just get yourself some poly mounts and bushings for everything back there. They help greatly. Ask me how i know. Good luck man.
Re: sweet dude
Originally posted by transxtreme Yea, that will bolt right up no problem. Just get yourself some poly mounts and bushings for everything back there. They help greatly. Ask me how i know. Good luck man. |
hahaha zeph...
prolly cause hes moshed a few oem rubber mounts
Originally posted by kevin 2.8 prolly cause hes moshed a few oem rubber mounts |
So what's the plan with the rear? Are you gonna put the 9-bolt in or pick up a posi and run those 3.73's you bought? The 9-bolt is tougher (as I'm sure you know) but the 3.27 ratio isn't really deep enough for the 6-speed, and a set of gears for the 9-bolt is gonna be pricey.
Originally posted by TheGreatJ So what's the plan with the rear? Are you gonna put the 9-bolt in or pick up a posi and run those 3.73's you bought? The 9-bolt is tougher (as I'm sure you know) but the 3.27 ratio isn't really deep enough for the 6-speed, and a set of gears for the 9-bolt is gonna be pricey. The motor is out. Talk about pluming/emissions stuff/etc in the engine bay. I have no clue what half of that stuff is. Geuss I'll be asking a lot of questions :p Tuesday after work I'm going to at least pop the valve covers. Depending on time, I'm going to try to pull at least one head and check things out. NOTE: Site will not be updated until tomorrow night. The extraction took a smidge longer than expected. -Corey |
Glad to hear bout your luck. Car is coming along good i see.
What you going to do with the leftover parts you don't use? |
Originally posted by hairbear Glad to hear bout your luck. Car is coming along good i see. What you going to do with the leftover parts you don't use? |
we might need to get together and do some buying/selling or swapping/trading. I could use some of the ta parts on my 91,like the 9 bolt,seats maybe.
Originally posted by hairbear we might need to get together and do some buying/selling or swapping/trading. I could use some of the ta parts on my 91,like the 9 bolt,seats maybe. -Corey |
Hey when you get ready to unload that TPI rig let me know. I've been lookin for one to stick on the next motor for my 4x4.
Originally posted by TheGreatJ Hey when you get ready to unload that TPI rig let me know. I've been lookin for one to stick on the next motor for my 4x4. -Corey |
