Need help from carbed guys
Old Oct 17, 2003 | 06:09 PM
96cam4ro's Avatar
What size air cleaner do you use with the edelbrock Air Gap intake manifold and a 650 cfm carb to fit under the stock Camaro RS hood?
Old Oct 17, 2003 | 08:11 PM
1SLOSBC's Avatar
you really need to run a drop base filter to clear the stock hood, and you CANT run one with a edelbrock carb.
try a lil 7 or 9" deal that has the paper element. they are only one inch tall. will fit, but reduces airflow. bigger filter, more air.
good luck!
Old Oct 18, 2003 | 01:50 AM
96cam4ro's Avatar
So how high of a cowl do I need to clear a 14x3 non drop base air cleaner?
Old Oct 18, 2003 | 02:05 PM
TheGreatJ's Avatar
Not true. I'm running a Performer RPM (old style, non-air-gap) intake, Edelbrock 750 carb, and 14x3 K&N with a 1" drop base air cleaner. It clears the hood with room to spare.
Old Oct 18, 2003 | 04:32 PM
96cam4ro's Avatar
Smile
You just saved me $700 for a cowl hood (shipped, painted and installed).
Old Oct 18, 2003 | 05:38 PM
1SLOSBC's Avatar
must be a really close fit, i run a 3" drop base with a 4" filter on an SS hood.
cool deal. good luck!
Old Oct 18, 2003 | 11:17 PM
TheGreatJ's Avatar
It clears by about 5/8"
Make sure your motor mounts are good because if they let the engine shift too much the air cleaner will hit the hood.
bose
Jan 30, 2015 02:36 PM
InfernalVortex
Jan 17, 2015 09:35 AM
markaubuchon
Jan 14, 2015 01:48 AM
Red97LT1
Aug 7, 2002 05:45 PM
