Need help after motor install
Old Feb 17, 2004 | 05:09 PM
84t-topZ's Avatar
I spent last weekend swappind a motor into my Z/28
when i bought the motor the heads had been removed so i reinstalled them.
i did not use thread sealer ( i didnt know i was supposed to)
on initial start up i noticed sweet smelling white smoke from the tailpipes, but thought nothing of it.(I'm a retard i kow)
i was able to drive the car maybe MAYBE 20 miles and the thing overheated but didnt show an overheat on the temp guage
the car slowly lost power and stalled
when i stopped steam came billowing out of the carb
i noticed antifreeze dripping off the intake manifold onto the exhaust manifolds and there was antifreeze in the oil but not vice versa
a friend got it running today but it keeps overheating
give me some suggestions please?
Old Feb 17, 2004 | 05:15 PM
Rice Killer87's Avatar
u said there was antifreeze in the oil..as in u pulled the dipstick out and it was white-ish/milky looking? if it is and u drove it a while im sure the motor is done for and now its time for a rebuild.
good luck
Old Feb 17, 2004 | 05:22 PM
84t-topZ's Avatar
i did stop right after it stalled
the temp guage on the dash didnt read any higher than it ever did with the LG4 in it
Old Feb 17, 2004 | 06:37 PM
TheGreatJ's Avatar
If it's got coolant in the oil and has been run hot, then it's got a blown head gasket. Or maybe a cracked head. And possibly bad bearings (depending on how much coolant was run though them instead of oil.)
Run a compression check on all 8 cylinders, and if any of them are more than 10% less than the others go ahead and tear the heads back off. You may also want to run it for a couple minutes with a GOOD mechanical oil pressure gauge to make sure the bearings will hold pressure. Let us know what you find.
LeftoverChinese
Jan 14, 2024 03:03 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
