need help
Old 01-03-2011, 12:00 PM
anthony22893's Avatar
need help
I recently pick up a 350 for cheap and i am interested to see what exacly it is, is there any specific way to tell what exact motor i have and what hp its rated at? thanks
anthony22893 is offline
Old 01-03-2011, 01:07 PM
Marc 85Z28's Avatar
Re: need help
www.mortec.com Use that to identify the block and heads. Use the block and head information in Google to get an idea of the donor vehicle and/or power rating.
Marc 85Z28 is offline
Old 01-03-2011, 03:09 PM
Re: need help
has anyone here every put the 400 crank in a 350 block to make it the 383.
Old 01-04-2011, 01:14 AM
ZZ
ZZ's Avatar
Re: need help
Thousands of folks used to do it before you could get cheap stroker kits. If I remember correctly, The main journals need to be turned down .20, ( 2.45 vs 2.65) and you have to either use the shorter 400 rods or pistons with a different pin location. Nowadays it ain't worth it when a 383 stroker kit is one stop shopping.
ZZ is offline
