Name that tune? rear end noise?
Old May 4, 2003 | 12:12 AM
OrangeIROC's Avatar
Hey, i have a 1988 IROC-Z, when i'm driving at a constant speed or i get on the accelorator at all, say about 30+mph, there is a whining sound comming from the rear end, and also, anything under 30mph, i hear a clicking noise.. What is it? Spider Gears? I still have Posi and firm shifts, just that dang noise.. What is it and how much to fix it roughly? Thanks guyz..
Mike
Old May 4, 2003 | 06:56 AM
Dave89IROC's Avatar
does it go away when you coast (let off the gas to slow down) ?
Old May 4, 2003 | 11:39 AM
OrangeIROC's Avatar
when i'm driving at like 30+ mph, and i let off the gas the noise does stop, however if i'm under 30mph it will still click.. for for some reason when its over 30 i dont hear clicking, maybe everythings just spinning too fast.. Any ideas?
Old May 4, 2003 | 12:59 PM
DarthIROC's Avatar
From: Teeter-tottering between Brilliance and Insanity
Kinda sounds ike mine when the ring and pinion ate it. Mine was torn up pretty bad when I took off the differential cover. But it never made a skip in persormance yet, just bad noises. So I guess it will work right up till when I finnaly decides to tottaly quit working if you leave it be.
Old May 4, 2003 | 05:33 PM
TheNovaMan's Avatar
It might not be a bad idea to pull the differential cover and check the oil for metal flakes. If you find much, you know you've got a problem. If you're lucky (or maybe unlucky?), you might even be able to see the problem.
Old May 4, 2003 | 06:02 PM
Zepher's Avatar
Sounds like you have some cracks in your pinion gear.
Definately pull the cover and inspect the ring and pinion.
Old May 4, 2003 | 11:14 PM
OrangeIROC's Avatar
Hmm bummer, this whole time i was thinking that it was just the spider gears.. So i guess if its the Ring and Pinion gear i should probly just upgrade my gears while i'm at it right? 3:73's sound good to you guyz?
Mike
Old May 4, 2003 | 11:47 PM
Zepher's Avatar
Ya, if it turns out to be the gears, 3.73 sounds good.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
Collector Car
Jan 5, 2015 10:58 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
