mystery fluid
Old Aug 14, 2003 | 08:11 PM
lordmetalz28's Avatar
Unhappy mystery fluid
hey question im leaking a fluid from what looks like behind the oil pan. i thought it was oil but i never lose a drop on my dipstick. so i checked my brake fluid today and it was just about empty so it must be break fluid. do brake lines run from behind the pan or is there something that runs from behind the pan that could carry break fluid
Old Aug 14, 2003 | 09:58 PM
TheGreatJ's Avatar
The brake line for the rear brakes runs down the tranny tunnel. It may have a small hole in it.
Old Aug 15, 2003 | 01:11 PM
OneSickS10's Avatar
Where does your passenger side caliper get fluid from? I haven't checked on the camaro's but my S10 has a T-junction on the crossmember on the drivers side, where 1 goes to the drivers side caliper and the other goes along the crossmember to the passenger side. With all the wind blowing under the car when you drive, it could be getting blown onto the pan and dripping from there.
If its an auto transmission.. if might be your front pump seal, behind the torque converter... check out the color and smell of the fluid.
Red - tranny
Black or Beer color - Oil
Clear - Brake fluid
Old Aug 15, 2003 | 05:43 PM
TheGreatJ's Avatar
Yeah the pass. side front caliper line runs along the K-member. That's another good possibility.
Old Aug 15, 2003 | 08:34 PM
its brown and its not oil its break fluid so i should jack it up and view under there it lost almost all its fluid but it took from june till now so its small
93 RedBird
Nov 15, 2015 08:24 AM
blac94Z
Nov 4, 2015 01:59 PM
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
