More Supercharger/Turbocharger info..
Old Jan 19, 2003 | 01:30 AM
90rocz's Avatar
Here's some stuff I dug up early in the book I'm reading"Supercharging,Turbocharging and Nitrous Performance Handbook".
**Positive Displacement(screw type)Superchargers can generate high levels of boost at low engine speeds.(1000-6500usually) Centrifugal superchargers generate a comparatively small amount of boost early in the rpm range. And is basically a belt driven turbo.
Typically the centrifugal blower will continue to increase gradually with engine speed , but is also limited by engine speed, or max rpm.
Heavier , underpowered autos tend benefit well from "screw" type blower, while light overpowered autos are better suited with a centrifugal set up.
Typically the lager the case of a "roots"(screw) blower, the greater its output potential. While pulley/gear changes will better increase the output of a centrifugal blower.
A "roots" blower capable of blowing 20lbs of boost into a 400ci motor would be both big and heavy compared to the same, capable centrifugal blower.
The speed and shape as well as size of the centrifugal's impeller/housing, determines its output.
**There are alot of formulas in here too, if you like theory.**
When properly sized a turbo will deliver outstanding performance with few concessions. A turbo is more efficient than a supercharger both; thermally and mechanically.
From a mechanical standpoint a turbo reacts to load rather than engine speed. Which means it does not impose a load penalty on the engine unless it's making boost. Turbo lag occurs b/c the compressor assembly can't react as quickly as the engine. By comparison the speed of a belt driven supercharger accelerates and decelerates at the same speed as the crankshaft having virtually no lag.
Since the impeller and compressor aren't phisically attached to the engine, "INERTIA" becomes a formidable force. B/c exhaust gasses drive it the gasses must reach a high enough volume to make the turbo react. The time it takes for this is called Turbo Lag .
Turbo Lag is unavoidable, but can be minimized to a large degree tho. As a general rule the larger the turbo, in relation to the size of the engine the greater the Lag. The reason is simple , more energy is required to accelerate(move)a larger mass. However a smaller turbo will be quick to react but be limited in overall output.
there's more but I'm tired...later.
Old Jan 19, 2003 | 03:11 AM
stonedchihuahua's Avatar
Someone who actually knows!!!
Old Jan 19, 2003 | 06:57 AM
iroczinoz's Avatar
In the other thread we had a discussion one Turbo or Supercharge what is better. Well we came to the conclusion that a SuperCharger puts more stress on the engine.
Well how much more stress does a supercharger put on the engine then say the A/C compressor and Smog Pump combined?
Does it put more stress or can we say running without A/C and Smog Pump will let you run a Blower without stressing the engine more then the A/C and Smog Pump already do?
I was just thinking on a long drive today, and thought I must not forget to post this and ask the fellas who know.
Old Jan 19, 2003 | 07:54 PM
Chris Ja's Avatar
Eternal Member
That is a good question. It is the same as running the a/c when under boost. It puts a stress on the engine ie crankshaft and heat to pistons. Makes 4 or 5 runs back to back with a supercharger and see how long your piston rings last.
As was stated from the book"When properly sized a turbo will deliver outstanding performance with few concession. A turbo is more efficient than a supercharger both thermally and mechanically. From a mechanical standpoint a turbo is more efficient". That is the point we were trying to make before. You may be able to make more power with a supercharger but if the engine keeps breaking then which is better. I would say most guys on the board can't afford to replace there engine once a year or more depending on how much you race. Anyone here can build whatever they want. The fact is some of us will be driving while some will be walking.
anaoj04
All Non-Automotive
Feb 16, 2012 06:33 PM
si
Oct 27, 2011 02:35 AM
chvlle383
Sep 15, 2011 05:46 PM
sweetp10
Jul 23, 2011 06:15 AM
Bayer-Z28
Apr 7, 2011 09:03 AM
