More power froom chevy heads? 350....
Old Mar 5, 2004 | 11:27 PM
Eric G's Avatar
I have access to a 350 short block, I could get it for next to nothing.
What chevy heads make the most power stock? I wund be using a air gap intake probbaly ( idle to 5500). And a aftermarket cam.
And what cars / trucks could I find them on?
Old Mar 6, 2004 | 12:18 AM
97WS6SCharged's Avatar
Probably the Vortec 350 truck heads.
Old Mar 6, 2004 | 12:26 AM
Eric G's Avatar
Thats what i was thinking, what years / modles can I get thease off of?
Old Mar 6, 2004 | 12:43 AM
zrs's Avatar
zrs
From 1996 and up Chevy truck. Look for a casting # of 062 or 906
Old Mar 6, 2004 | 12:48 AM
Sitting Bull's Avatar
The only problem is you need a special Vortec intake manifold, too.
On the other hand, you can port and polish a set of 305 heads which will work very well on that 350 for not much moola. Follow the link at the end of my sig.
Old Mar 6, 2004 | 01:17 AM
pwrhngryj's Avatar
Talking heads
Go with the vortec heads from a 96-99 350, get the heads cut for high lift springs. Keep the stock angle valve job (a three angle will kill about 10-15 CFM on these heads) and run a victor vortec intake, a 750 DP holley carb, and a cam with about a 480 lift and a 230-240 duration @.050. With this combo you can expect to get about 430-450 horse power @ 5500 and about 460Ft./Lbs. @4500 with 11.0-1 compression. Power will obviously be lower with a lower compression ratio.
Old Mar 6, 2004 | 01:41 AM
Eric G's Avatar
Is there any where I can buy them already cut?
Where could I have them cut and where could I get valve train stuff? (springs , retainers , valves ect ect?)
Old Mar 6, 2004 | 01:48 AM
Eric G's Avatar
Will thease work?
http://www.sdpc2000.com/cart.asp?act...art&catid=2172
What intake to go with them? Preformer or preformer RPM?
Upgraded vortech heads
Old Mar 6, 2004 | 11:21 AM
aklim's Avatar
The iron vortec heads, whether any port work has been done to them will work on our cars. However, if you want to go FI you have to use their manifold. Otherwise, if you go carb, there are more choices. So, if you want to use their heads, you cannot have a SR, MR or HSR setup
Old Mar 6, 2004 | 01:14 PM
Eric G's Avatar
Im going to go carb.
Its gonna be going into a rust free, 84 S-10 I picked up for next to nothing. They are really light, so 400ish Horse power Will make it Fly.
Maby If its not fast enought ill add a 100 shot.
But no FI
Old Mar 7, 2004 | 07:21 PM
Eric G's Avatar
Re: heads
Originally posted by pwrhngryj
Isnt a victor to mcuh intake for vortecs?
Old Mar 7, 2004 | 08:23 PM
AutoRoc's Avatar
A Super Victor Vortec manifold is never "Too much" for the heads. As a true car guy I'll ask you this... What is your definition of TOO MUCH? What kept me from getting a Super Vic intake and just doing an RPM Air Gap was low end torque. For better acceleration numbers a Super Vic would be better easily with even my current combo but I drive the car a lot on the street and a lower torque peak would make the car better in Solo 2 racing sitations. Oh yeah and keeping rpms down is a good way to preserve engine life, especially if you aren't running top notch parts.
Choose camshaft accordingly. Goodluck!
Old Mar 7, 2004 | 08:34 PM
Chuck!'s Avatar
I love my Performer RPM with the Vortecs although Im running tbi.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
