Master Cylinder squirting?
Old Sep 23, 2012 | 06:21 PM
Steve350Z28's Avatar
I recently purchased a 91 1LE Camaro. with 60K on the odometer.
The brake performance was very bad from the start.
The brake fluid was black as night.
I replaced the master cylinder and bled all the brake lines using a kit that I hooked up to my air compressor.
I bench bled the master cylinder before installing it on the car.
I did this once before on my first car, an 84 Z28... in 1996.
I stopped bleeding it when I stopped seeing air bubbles.
What I did see however and was unsure if it is correct is fluid squirting out of the front most reservoir when pressing in the piston.
This fluid is still squirting out of the front reservoir with the Master Cylinder installed on the car (to expect anything else would be silly, I know).
Is this a sign of a bad Master Cylinder?
The calipers are getting piston pressure but there's not a lot of stopping power.
Thanks.
Old Sep 23, 2012 | 11:29 PM
Z28SORR's Avatar
Re: Master Cylinder squirting?
Yes this is normal. Push slower.
When you bled the master cylinder did you get all the air out of BOTH the front and rear reservoir? The front is fairly easy but you have to push very hard to activate the rear half.
At this point with it installed I would re-bleed the system. Pedal should be hard with only an inch or two of movement.
Old Sep 23, 2012 | 11:35 PM
It only requires me tapping the pedal for that to occur.
I did get all the air out of both halves.
I bled the entire system after I installed the master cylinder.
I have a question regarding the caliper pin on the 1LE dual piston calipers: Should it be lubricated?
Thanks.
Old Sep 25, 2012 | 02:21 AM
Z28SORR's Avatar
I've always put a little dab of grease on the end of the pin where it contacts the piston. Never seen anything that says it's required.
G-BODYT56
Jan 14, 2022 11:14 PM
94Maroz28
Oct 27, 2015 04:38 PM
jayblev95
Sep 26, 2015 09:44 PM
Daluchman1974
Sep 11, 2015 06:12 AM
jackpawt883
Sep 10, 2015 08:53 PM
