LT1 in third gen wanting to add cruise
Old Apr 1, 2003 | 02:21 PM
sinner's Avatar
has anyone here done the LT1 swap and kept cruise control? i need to know if i should use the 1995 system or the 1992 system, and how it is done.
i am almost done and that is one of the remaining ends, i tried 2 other boards with no help.
Old Apr 1, 2003 | 04:51 PM
Dave89IROC's Avatar
I think you should use the 95 system , and just modify/adapt the
switch in your car to work with it
Old Apr 1, 2003 | 07:20 PM
sinner's Avatar
what are the benefits to doing that rather than useing the 1992 stuff?
Old Apr 2, 2003 | 06:00 AM
jzajac1's Avatar
If you're using the 92 harness and ECM - that's what you use. If you're using the 95 harness and ECM - that's what you use. The cruise picks up it's vss signal and ground from the ECM. 92 & 95 ECM's were programmed slightlty different for cruise function.
Old Apr 2, 2003 | 09:32 AM
sinner's Avatar
well, im mostly using the 95 stuff, but i blended the 92 stuff like the fans etc. into the 95 harness. thats a logical answer, and im glad someone is haning some ideas. thank you.
Old Apr 2, 2003 | 10:02 AM
rickyzZ28's Avatar
I would have to say since the motor anbd tranny is from a 95 you should use the 95 equipment. Your 92 has a cable cruise where "I think" the 95 uses an electronic cruise setup. I know on my 93 motor there is a spot on the throttle body for the cable cruise setup, but 93 also didnt have the 4L60-E tranny.
Old Apr 2, 2003 | 02:12 PM
sinner's Avatar
actually im using the 92 tranny, which is a 700R4, not the 4L60E from the 95. im sure that will make a difference.
Old Apr 2, 2003 | 02:35 PM
rickyzZ28's Avatar
So it has a a different year throttle body on it though right? (not 95). If this is true then you should be able to use your third gen setup.
Old Apr 2, 2003 | 08:18 PM
sinner's Avatar
yes, when im done the thirdgen stiff will work
if thats what i need to do, thats why im trying to figure this out
jayblev95
Jan 20, 2015 01:30 PM
cmdeshon
Dec 27, 2014 10:06 AM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 7, 2014 06:01 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
