lt1 super ram or stealth ram ??
Old Mar 12, 2004 | 07:44 PM
highboost's Avatar
ok does anyone have experience w/ thes intakes on a 350 eng?
heres set up zz4 shortblock. im using a comp xtreme energy 12-242-2 260/280 dur. 477/480lift cam , ported l98 heads, slp 15/8 headers 52mm tb, 1.6 roller rocker,msd 6al ign. & 75 shot spray
i need opinions on what of these 3 intake will best compliment my set up????
Old Mar 12, 2004 | 08:02 PM
aklim's Avatar
If you need to pass emmissions, the HSR is not for you. Go with SR.
Old Mar 12, 2004 | 08:04 PM
highboost's Avatar
thank god kansas has no emmisions laws
Old Mar 12, 2004 | 08:09 PM
stealthramman's Avatar
I put the stealthram onto mine and absolutely LOVE it. It has tons of torque down low but pulls hard all the way to 6000 where i have my limiter set. All that with a cam that peaked at 3800 on the dyno with the tuned port intake. With the tuned port it would hardly go past 5000!!
Do a search on the site for more info. It's a fairly easy install. All i have to say is good things about that manifold. The only thing to keep in mind is that you should get a custom chip for it once the intake is on. The ignition advance curve tuning is way different for the tuned port intake. With the HSR intake the motor likes lots more timing, and is not so sensitive to knock. You'll also need to add fuel at the top end.
Because the rpm range is extended so much, i then went with a higher stall convertor. That addition really made the combo. Your car will scream!
My .02 from someone who's been there.
Old Mar 12, 2004 | 08:22 PM
highboost's Avatar
do you think w/this set up i will acheive my 350hp @wheels goal???
Old Mar 12, 2004 | 08:30 PM
Assuming a 20% driveline loss, you'd need 420 hp at the motor. You'll probably need some better heads and a bigger cam to get you there. Of course the NO2 will also help alot! You'd only need about 345 at the motor before the 75 shot, which is doable. I'd recommend a nitrous activated timing retard to be safe. I think you can get an add on kit for your MSD(?) depending on which unit you have.
Old Mar 13, 2004 | 02:42 PM
amc91z's Avatar
I've messed around with the stealth ram, super ram, and the mini ram....the mini ram was the best in my opinion. But I like the stealth ram ALOT better than the super ram! I've got the stealth ram on my blown 383 now
Adam
F'n1996Z28SS
Aug 23, 2023 11:19 PM
RUENUF
May 25, 2016 08:10 PM
rcajun86
Jan 30, 2015 01:56 PM
rjc1629
Jan 27, 2015 10:46 AM
